Results 1 to 4 of 4
Thread: block id help please
    GREEN=FAST sweeney1030's Avatar
    johnstown
    570
    the rear of the block near the bell the stamping 1h227984 appears can anyone help me id what it means ? if it helps there is a 2 cast into the valley between the lifters and a ford oval with the script into it.. if anyone knows please text me as im not online that much or leave a message on here. thanks alot 814 243 3778 is my cell.
    never stock biminiLX's Avatar
    Beaver
    2,406
    What motor? 302/351/Mod?
    Windsor 303/351 blocks casting number should start with a letter then number to give casting date, example casting starting with F4 is a '94 casting for a 351 truck roller motor.
    johnstown
    570
    bump
    johnstown
    570
    it is def a 302 .i got some more details that may help .the heads are non egr units with 48 cast into them and 302 cast into them , there is a tiny plate between the rocker arms that is screwed into both heads that has B on it .it has a right side front dipstick . the rockers appear to be cast and have FA on them and they are straighter than the 91s i have . the only thing i get from the rear of the block is 1H227984. i hope this will help.
  1. 324 Boss Block Big Bore Stroker short block $2,900 O.B.O.
    Last Post: 05-03-2014, 04:19 AM
  2. Replies: 14
    Last Post: 02-22-2014, 01:52 PM
  3. WTB - Mild 331/347 short block or long block
    By PaceFever79 in forum Ford Parts
    Last Post: 07-11-2010, 07:05 PM
  4. wtb 351w roller engine, block or pre 74 block
    Last Post: 04-08-2009, 11:27 AM
  5. block ?
    Last Post: 10-03-2008, 02:28 PM
