Results 1 to 9 of 9
Thread: 2007 window problems??
    State College, PA
    3,552
    Arrow 2007 window problems??
    So my gf's mom has a 2007 cali special stang with only about 1600 miles on it.
    just recently its been having a problem. when you turn the car off, get out and shut the door, the driver side window rolls down automatically. keys are out of the ignition and the window goes up and down fine when car is on.
    so what's the deal here? never seen this before. and car has almost no miles on it??
    2013 Mustang GT
    1999 Contour SVT
    State College, PA
    3,552
    it also sits in a garage all the time so i highly doubt anything got wet
    2013 Mustang GT
    1999 Contour SVT
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    I know when you open the door the window slides down a little so maybe whatever controls that is messed up.
    2019 Hellcat
    Sep 2007
    Dayton PA
    3,795
    I dont know for sure but i bet the window control is in the body module.
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    The short drop function is built into the "smart" p/w motor, the short drop is when the door is opened and the window goes down slightly, the p/w motor monitors and is activated by the door ajar switch. The one touch up/down function is built into the p/w switch. The two components I would suspect would be either the p/w switch or the motor. If the concern can be duplicated on a regular basis, I would disconnect the driver p/w switch and see if it still does it. If it does, I would suspect the p/w motor, if the concern is eliminated I would suspect the p/w switch. Hope this helps
    Sep 2007
    176
    There is a way to reset this, look in the manual. I think you turn the key on and hold the button in the up position but I'm not sure.
    2,483
    Try this.
    1 - While the window is in motion, either up or down, disconnect the battery or pull the fuse. I think it is easier to diconnect the battery. It is important that the window is in motion while losing power.
    2 - Wait 1 minute and reconnect the battery cable. After the cable is secured to battery post, push or pull both window buttons so that the windows go all the way up and then all the way down. You will hear a little click (usually) when it is almost to the top. This will relearn the window module. Done.
    Cranberry Twp.
    344
    Quote Originally Posted by Silverhatch View Post
    Try this.
    The p/w could bounce back due to needing reinitializing
    Guess I kinda over analized it
    State College, PA
    3,552
    thanks guys ill let her know next time i see her and try to get it fixed
    2013 Mustang GT
    1999 Contour SVT
  1. having problems with my 03 cobra
    By chargedcobra03 in forum SN95-New Edge
    Last Post: 05-28-2013, 02:59 PM
  2. Fox'vert rear window problems
    By Dan B. in forum Fox-SN95
    Last Post: 03-27-2012, 07:46 AM
  3. t5 problems???
    Last Post: 05-10-2011, 05:51 PM
  4. Power window problems
    By v6mustang01 in forum General Tech
    Last Post: 05-08-2009, 12:05 PM
  5. Nitrous Problems
    By Import Killer in forum The Bar
    Last Post: 11-07-2007, 12:32 PM
