Hi guys.
I need some advice here.
I have my transmission and clutch out to replace the pilot bearing and rear main seal before installing a Tremec 3550 and new clutch and I noticed that I have a leaky oil pan at a few spots. Already replaced the rear main seal but the pan is a 4 piece and is leaking at the front and back.
Question is... Can anyone tell me how I can replace the pan with a Moroso 7 qt without pulling the motor? Drop K-Member? Remove pump and pickup before pulling the pan out? Raise motor? Remember that I have the trans out already.
I just didn't want to start tearing stuff apart only to find out that I have to yank the motor out. I would rather not pull the motor since I finally got the damned car 2 feet up in the air to work on the trans and clutch.
Any advice? Can this be done, really?
