Results 1 to 17 of 17
Thread: Oil pressure issues
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Oil pressure issues
    I'm posting this on behalf of Vitaleffects. He sent his block out to clean prepped for a new crankshaft. The place installed new cam bearings and sold him new pistons, main bearings, etc. Eric decided to put the rotating assembly together himself. Well the issue is that the car starts fine, runs great for the first 10-15 minutes, then the oil pressure drops to zero. Ugh.
    Well after some research he decided that the high volume pump was the source of him problems. Today we installed a new Ford racing pump and shaft, put the thing back together, and we still have the same problem. Double ugh.
    :o
    2015 GTPP
    Mar 2009
    796
    Sounds like he forgot one of the 7 oil plugs. There are 3 plugs in the rear of the block,
    3 in the front timing chain area, and 1 in the top rear of the lifter valley.
    If the block was tanked one of them maybe missing.
    Mar 2009
    796
    Most likely it's not one of the rear plugs as oil would be running out the bell housing.
    So that leaves the 3 up front and the one in the lifter valley.
    :o
    cam bearing oil holes lined up ????
    JUNK IT!
    Huntingdon PA
    1,136
    did you check the bearings? sounds like exactly what my piece of shit DSS motor did when i bought it and it blew apart in 750 miles. Main bearings were gone on a 2500$ motor.
    709RWHP/750RWTQ
    1,344
    Talked to Eric last night. It sounds like he is going to take the motor out and send it to the machine shop for them to fix it. He won't be at Carlisle this year. Sucks.
    2015 GTPP
    Mar 2009
    796
    I've seen this happen before. If low pressure presented itself during the initial start I'm
    pretty sure they either left out one of the plugs in the cam galley, or one of them came
    loose. The plugs are just pressed in like little freeze plugs.
    If one was missing the mains and rods get oiled, then pressure bleeds off and starves
    the cam and valvetrain. If you have everything lubed up with cam lube and didn't run
    it too long, it may not have done any internal damage.
    Best to let the machine shop sort it out.
    1,344
    Thanks Pace. Good or bad, the car has been started atleast 10 times, and each time it ran for 10 minutes before pressure dropped to zero.
    The plug idea is good, but I think you are right that we would see low pressure from the moment we started it.
    Time to yank it!!!
    2015 GTPP
    South Hills, PA
    4,052
    who is the said machine shop?
    did you try a different gauge?
    1,344
    Bill-I think he is going to try SMO.
    John-We tried two different gauges after the first time the factory gauge dropped. We were hoping the factory unit was junk, but that doesnt seem to be the case.
    2015 GTPP
    Mar 2009
    796
    I'd still pull the timing chain cover and intake just to see if an oil plug is
    missing. If they are there then pull the long block for rebuild.
    If one of the plugs inside is leaking it can hold 15-20 lbs of pressure until
    the oil thins out after warming up and then it drops to zero.
    Think of it as a percentage of pressure bleed.
    1,344
    It's worth a try for sure!!!
    2015 GTPP
    Ok guys I pulled off the lower intake and the back oil plug looked a lil funny so I very very lightly taped on it and it dropped a 8th of a inch could that be it
    Mar 2009
    796
    It should be snug, like a freeze plug.
    Replace the plug, then put it back together and try it.
    If that doesn't cure it, pull the timing cover and inspect the front plugs.
    Mar 2009
    796
    To answer your question, it could be the problem.
    If it was loose it would leak more as the oil thins out with heat.
    If it was missing you would never build any pressure.
    1,344
    Should have checked plugs before rippin the entire car apart yesterday. :) Put it back together and try man. You should have it ready to go by noon....We will be waiting for an update.
    2015 GTPP
  1. question on oil pressure
    By vitaleffects626 in forum General Tech
    Last Post: 03-19-2011, 05:19 PM
  2. need help with oil pressure
    By blaze00 in forum Fox-SN95
    Last Post: 09-03-2009, 10:01 PM
  3. Lunar Oil Pressure Gauge
    By BrentK in forum Ford Vehicles
    Last Post: 04-01-2009, 03:52 PM
  4. how to check oil pressure
    Last Post: 04-08-2007, 09:09 PM
  5. oil pressure????
    Last Post: 10-27-2006, 05:01 PM
