Results 1 to 1 of 1
Thread: Main Seal Replacement #1
    Member Warrior1670's Avatar
    Oct 2010
    Cranberry Township, Pa
    97
    Thanks for the help on the tranny removal fellas! So the bottom passenger side tranny bolt was already stripped and I had to cut and grind it off, other than that, no problems. Why couldn't Ford give us one more inch in the shifter hole to the rear so we don't have to take the shifter out!
    Attached Images Attached Images
  1. Rear main seal replacement 03 Cobra
    By Terminated in forum SN95-New Edge
    Last Post: 02-01-2012, 01:49 PM
  2. SN-95 5.0 rear main seal replacement
    By Warrior1670 in forum Fox-SN95
    Last Post: 02-18-2011, 01:50 PM
  3. rear main seal questions???
    By White5.0 in forum Fox-SN95
    Last Post: 06-18-2010, 01:14 PM
  4. Rear Main Seal 04 Cobra
    By burntire in forum SN95-New Edge
    Last Post: 01-26-2009, 07:46 PM
  5. It is never simple, which rear main seal?
    By DRRummel in forum Fox-SN95
    Last Post: 11-21-2008, 10:36 AM
