Results 1 to 2 of 2
Thread: Identify this clutch
    Member Warrior1670's Avatar
    Oct 2010
    Cranberry Township, Pa
    97
    Anyone help ID this clutch? Is it factory, centerforce, spec?
    It was supposed to be replaced but I'm not sure. The only marking is the "d2" looking mark.
    Also, the friction plate....how much material does a new disk have to the rivets? This one has maybe an 1/8" from the top surface to the rivets, maybe a little less (I didn't measure, just eyeball'd it).
    Specs covers are all painted blue, typically centerforce is Orange so I'm not seeing it as one of theirs. No help on wear, I run metallic clutches that wear the flywheel and pressure plate rather than the disc.
  1. Coilovers, can you identify these
    By madmaxin22 in forum General Tech
    Last Post: 06-12-2014, 07:42 AM
  2. can someone identify this part
    Last Post: 03-01-2010, 07:17 PM
  3. how to identify 2.3 vs 2.5 ranger motor?
    Last Post: 08-03-2008, 04:01 PM
  4. help me identify this FPR
    By White5.0 in forum Fox-SN95
    Last Post: 07-27-2008, 02:10 PM
  5. Please help identify this electrical part:
    By DRRummel in forum Fox-SN95
    Last Post: 03-15-2007, 05:39 PM
