Results 1 to 20 of 28
Thread: 5.oh
    4,321
    5.oh
    We installed some lower control arms, shifter and lowering springs today. The car also has a catback and CAI, we put her on the dyno for some power pulls
    Nice!! What shifter and what catback?
    4,321
    Steeda shifter, Magnaflow competition catback. Installing another Magnaflow competition catback on another CA 11 tomorrow
    Fuwkawee
    5,151
    I love that stance! I think lowering springs is my next mod.
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    4,321
    Quote Originally Posted by 2011GB/CS View Post
    Eibach Pro Kit so you know...
    Wouldn't happen to know what brand or who tuned it?
    Fuwkawee
    5,151
    Thanks Mike, I was wondering
    4,321
    Quote Originally Posted by Witt View Post
    It's a Steeda mail order...
    is that the normal numbers you have been seing from the new 5.0s
    4,321
    Seems pretty normal but I have only had a few on the dyno...
    Fuwkawee
    5,151
    Mike, when you installed those lowering springs did you have to do away with the strut tower brace?
    Senior Member Seer's Avatar
    Apr 2011
    800
    BMR was telling me, all you truly need is, the springs, new strut cap mounts, and recommended some camber bolts. As long as the drop isnt too aggressive. Oh and an adjustable panhard bar, as lowering the rear shifts the rear out to the left even more so.
    Also LCA Relo brackets since youre changing the angle too. These cars seem to be so sensitive to that.
    If you're going with an 05-10 style strut, you need to buy the GT500 style strut mount caps, instead of replacement 2011 caps or some CC plates.
    Never heard anything about the brace going away though.
    It might ride rough though if the spring was a little too aggressive for the struts.
    2022 BMW X4M Competition
    2019 McLaren 720S
    Fuwkawee
    5,151
    It will be an inch in the front and an inch and a half in the rear. I'm hoping I won't have to buy all the extra parts.
    Apr 2011
    800
    You're going to need new strut caps. The stockers pretty much fall apart when you remove them from what I've seen.
    The camber bolts are nice, and only $35. I can almost guarantee you should buy an adjustable panhard bar too, as it will shift the rear end out upon lowering.
    Relo brackets aren't 100% needed, but if you drag race the car, they will reposition the angle of your LCAs. I have a set waiting to go on, just haven't yet, because I'm sitting at stock ride height. I guess I could install it now, but just havent
    2019 McLaren 720S
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Please don't lower your car without buying real dampers, I know you are actually going to take it out onto the track, so I'm sure you don't want to be out there bouncing all over and hitting the bumpstops every corner.
    2014 M235i (wife's)
    1964 Ford F-100
    Fuwkawee
    5,151
    Yeah Mark, I do plan on tracking the car, I was just hoping I could lower it, and not do all this other crap buy spending a fortune on dampers and shocks and panhard bar. If that's the case I'll just keep the normal ride height.
    Trafford, Pa
    2,308
    Honestly, the Pro-Kit springs are pretty soft. Chances are you would be OK. The only problem I see is the reduction in bump travel. Most stock cars I have tracked are on the bumpstops often, so replacing the springs with ones that take away precious bump travel without adding much stiffness is a recipe to be on the bumpstops all the time. But for how cheap springs are, you could always give it a try.
    2014 M235i (wife's)
    1964 Ford F-100
    If You Wanna thedak's Avatar
    Jul 2008
    DMB
    Got them on my GTO and well worth it on the 5.0
    They go on sale for $1650 every now and then.
    https://secure.merlinsoftware.com.au...ProdCode=SM252
    https://secure.merlinsoftware.com.au...6-1304-B19537A
    Trafford, Pa
    2,308
    Do they publish spring rates? Can't find them on the site, didn't look too hard though.
    2014 M235i (wife's)
    1964 Ford F-100
    Apr 2011
    800
    great brand, but extremely overpriced. Can get much better performance going with a Tokico D-spec for less than 1/3 the price. Pedders in the mustang world has been compared to be on the same category as the "Bose" of suspension parts. Good performance, for 4x the price.
    Sam Strano who is a multi time winner using the S197 chassis, uses Tokico D-specs. For street cars, the Koni Orange (STR.T) is also highly recommended.
    Unless you're doing some serious competitive road racing, coil over setups arent needed, and if so, can be had a lot cheaper than Pedders.
    Pedders justified their insane pricing due to the fact they had little to no competition on the Holden platform vehicles, in which this seems to be carrying over to other makes and models now.
    2019 McLaren 720S
