Results 1 to 12 of 12
Thread: Mark8 fan install
    Jan 2008
    Jefferson
    4,674
    Mark8 fan install
    I need help installing a mark8 fan. I'm thinking since I have so much heat under my hood now with the turbo and 4v the factory v6 fan will not cut it. I ordered a mark8 fan but curious on a few things. Hoping somebody here can help.
    If I just plug it in normally will the high and low speed fans work normal?
    Will I need a new relay?? I've been ready they pull more juice and wasn't sure if I needed a new fuse, relay, or alternator for that matter. I'm running a factory reman alternator. Will that be enough?
    Kittanning/Butler
    1,055
    no clue, but good luck! oooo Carlisle! haha
    Sep 2007
    Dayton PA
    3,795
    it does just plug in. just find some way to mount it up! it was easy in the modular swap
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Jan 2008
    Jefferson
    4,674
    Do I have to change relays or fuses?
    Sep 2007
    Dayton PA
    3,795
    No i didnt and everything worked, it was a 96-97 body harness and computer
    01 cobra: traded
    Jan 2008
    Jefferson
    4,674
    I think the fan i got was from a 97. I'm hoping this cures my cooling issues since my front end has a small opening like the lincoln. I was told the lincoln fans flow the most air but put a stress on the charging system. My car only gets hot driving in very hot weather. Cool weather it's fine. Beating on it in cool weather it's ok. And driving normal in hot weather gets very hot.
    Brookline
    2,897
    If not, I'm pretty sure the 03/04 Cobra fan pulls the most air out of all, and will also adapt to original wiring.
    Jan 2008
    Jefferson
    4,674
    I was told the Lincoln fan did 5000cfm and 03 cobras were about 3500cfm??
    Sep 2007
    Dayton PA
    3,795
    the mark fan was easy to mount up I have pictures of the install somewhere...
    01 cobra: traded
    Jan 2008
    Jefferson
    4,674
    got the fan today the shroud wont fit with the turbo up front... only way it will work is if i change the fan motor and blade into the v6 shroud. going to do that and hope everything works and stays cooler!!
    98 gt
    Jul 2008
    Jefferson hills
    33
    you might need a fan out of a peterbuilt !!!
    1998 GT SN95 Forged 2V, Tremec TKO600, GARRETT T70 Turbo 548rwhp 605wtq @ 17psi.
    Brookline
    2,897
    Just what I had heard, not sure what the numbers were.
  1. 98 GT fan
    Last Post: 11-21-2009, 04:43 PM
  2. help with taurus fan install please...
    Last Post: 12-31-2008, 11:03 AM
  3. 1993 cooling fan/fan-clutch
    Last Post: 03-05-2008, 02:03 AM
  4. Electric fan
    By low12lightning in forum Ford Parts
    Last Post: 06-28-2007, 04:45 PM
  5. v-8 fan shroud
    By loutheplumbr in forum Ford Parts
    Last Post: 06-04-2007, 06:42 PM
