Results 1 to 16 of 16
Thread: 94-04 Mustang ABS Delete Manifold
    An easy installation to remove the factory ABS control module without having to re-plumb or flare the factory brake lines. It also allows you to go back to ABS brakes at a later date should you decide. All parts are machined and manufactured in the USA by PRB Machining. This is an "off-road" modification only!
    http://www.prbmachining-absdeletemanifolds.com/
    Phil
    2003 Mach 1
    NX 175 shot
    10.73 @ 128.63 (Oct 2007) factory motor
    Phil
    2003 Mach 1
    NX 175 shot
    New Store Item!! 94-97 ABS Delete Manifold With B&M Line Lock Solenoid Assembly Now For Purchase. No more splicing the Front brake line from mastercylinder to line lock solenoid. Only thing needed is to wire the line lock solenoid to in cab. This is a complet assembled item with bracket to mount to radiator support frame.
    Phil
    2003 Mach 1
    NX 175 shot
    Mt Pleasant, PA
    4,905
    Thats pretty slick!!!!
    Thanks! :D
    Phil
    2003 Mach 1
    NX 175 shot
    Some pics of the first 94 Cobra ABS Delete/B&M Line Lock Assembly mounted to under frame, while maintaining the factory brake lines. No splicing/flaring of brake line. Wiring is hidden by aluminum bracket.
    http://www.prbmachining-absdeleteman....com/id30.html
    Phil
    2003 Mach 1
    NX 175 shot
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Last edited by Mark Aubele; 08-18-2011 at 11:16 AM. Reason: Apparently I am an idiot
    2014 M235i (wife's)
    1964 Ford F-100
    Don't you have to be a vendor to pimp stuff on this site?
    I am a PAID vendor on this site! My banner is located in the upper right hand cornor when it shows up. "PRB Machining-ABS Delete Manifolds"
    Phil
    2003 Mach 1
    NX 175 shot
    Trafford, Pa
    2,308
    Quote Originally Posted by Phil View Post
    I am a PAID vendor on this site! My banner is located in the upper right hand cornor when it shows up. "PRB Machining-ABS Delete Manifolds" Please refrain from posting negative crap before you get the facts straight.
    I will go crawl back into my hole now. Carry on.
    Nice piece BTW.
    2014 M235i (wife's)
    1964 Ford F-100
    Nice piece BTW.
    LOL, thanks!!! :D
    Phil
    2003 Mach 1
    NX 175 shot
    For drag racing weight reduction. Remove 26 lbs by eliminating the rear bumper cross beam, brackets & styrafoam insert. The rear plastic bumper facia has 3 mounting tabs that can no longer be fastened to the cross beam.
    The light weight aluminum bracket support prevents the bottom of facia from flapping, giving rigid support. Stainless steel hardware supplied with bracket for complete install. Steel City Stang Members get $10 off price.
    http://www.prbmachining-absdeleteman....com/id72.html
    Phil
    2003 Mach 1
    NX 175 shot
    Phil
    2003 Mach 1
    NX 175 shot
    Coming soon to PRB Machining. Tormach PCNC 1100 Series 3 with Mach 3 machine controller.
    Phil
    2003 Mach 1
    NX 175 shot
    Not sure what that puppy does...but it sure is purdy!!
    Kittanning/Butler
    1,055
    I was thinking the same!
    I'll be able to machine the delete manifolds fast with fancy profiles and engraving. With the software, I can machine just about any profile shape. Also, I will be offering several other aluminum custom products for Mustang owners.
    Phil
    2003 Mach 1
    NX 175 shot
  1. 96-98 mustang gt intake manifold
    By jasons_98gt in forum Ford Vehicles
    Last Post: 06-21-2011, 02:03 PM
  2. abs delete manifold
    By Naste95 in forum General Tech
    Last Post: 03-09-2011, 08:46 PM
  3. '65 Mustang 2V manifold...?
    By 65 Fastback in forum General Tech
    Last Post: 06-19-2010, 07:19 PM
