Results 1 to 7 of 7
Thread: anyone with a stock fox.
Hybrid View
    Farmington WV
    4,672
    would you mind measiring your ride height.
    from ground to top center of fender lip. i want to see how much if any these LMM springs lowered my car...i only got the rear done and cant tell since i had eibach sportlines in there to begin with which was wayyy to damn low.
    so if you would...measure front and rear.
    2,483
    I can find out for you tomorrow. Won't be able to post till tomorrow evening though. How low was the car with the springs that were in it? Height from ground to top of fender lip?
    Farmington WV
    4,672
    i didnt measure sine i was taking the old eibacj stuff out.
    My vert actaly sits low....worn out springs and a heavy combo????? Either way, I was going to lower it but I dont think I need to. I can fit 2 fingers between my tires and fenders all 4 corners.
    My notch has ground pounders no room from tire to fender up front and about a fist full in the rear.
    Farmington WV
    4,672
    im just trying to find out if these LMM springs gave me much lower than stock height....im hoping at least 1-1.25"
    Mt Pleasant, PA
    4,905
    They should be right around an inch. You will need to get the fronts installed and drive it a little. They and all springs will settle a little.
  1. stock exh for a fox
    Last Post: 06-21-2012, 10:26 PM
  2. Stock Fox Headers????
    By ArmyWarrant in forum Ford Parts
    Last Post: 04-27-2011, 04:06 PM
  3. fox parts, mainly stock
    By fast4ord in forum Ford Vehicles
    Last Post: 03-29-2011, 09:53 AM
  4. Stock fox parts
    Last Post: 02-24-2008, 10:26 AM
  5. Stock Sterio FOX
    Last Post: 04-26-2007, 08:44 PM
