The driver's side window in my car doesn't go down. Through my research I've heard this is a common problem. I have taken the mentioned steps to try and remedy it (smack the door panel, slam door with UP button held down, etc) and nothing. I haven't taken the door panel off yet to tap the motor.
My question is, is the motor serviceable outside of the regulator assembly or do I need to replace it all? I figured I can get some answers to plan an attack rather than start tearing stuff apart right away. If I can pull the motor out without taking out the regulator, does anyone have any laying around that work?
Any other ideas to get it going? The pass side switch works as does the lock button. When I hit the down button I can hear it click, but no go on the motor.
Thanks
Dan
