Results 1 to 6 of 6
Thread: Fuel line spring lock fitting
    Anyone have any good tips on getting the MFR unhooked from fuel rail. I tried two different tools and for some reason it just won't come apart. Never had issues with it before.
    3,356
    I have used an open spark plug box, a small hose clamp that I took the screw mechanism off, some other misc items. Most times I use the spring lock tools or the white nylon open ones. I even have a couple other types of pliers made for these type of lines as well. Sometimes they are a real bitch. What are you using to separate it?
    Mark
    LeMans Blue Z06
    robinson
    1,091
    try pushing it together first then insert spring tool. sometimes that helps.
    /twocents
    fairmont,WV
    1,352
    Quote Originally Posted by bgblockelcamino View Post
    I was gonna suggest this....also I have had good success w/ the X shape ones that pivot in the center. Way more durable.
    XXX RWHP
    XXX RWTQ
    Tried pushing together. I will have to try something thinner to get under spring.
    Thanks for some ideas to try guys.
    Found problem to be with lil tool itself. Guy on another forum had same issue of tool not closing enough. Massaged opening with knife and it worked perfect once it closed up more.
  1. Line lock question
    By mustang50lx in forum General Tech
    Last Post: 03-10-2009, 08:24 PM
  2. Fuel line fitting.
    Last Post: 07-27-2008, 07:48 AM
  3. Line Lock Help
    By molnartr in forum General Tech
    Last Post: 03-29-2008, 07:44 PM
  4. line lock
    By tylerstepp in forum Ford Parts
    Last Post: 01-23-2008, 11:40 PM
  5. WTB: Line Lock
    By Mitternacht in forum Ford Parts
    Last Post: 12-10-2007, 10:50 PM
