Results 1 to 20 of 26
Thread: '90 5.0 runs rough only when in gear???
    State College, PA
    3,552
    Car starts and idles perfect. No surging. Revs fine in neutral no misfires or anything. But when car is put into drive it bucks badly and almost stalls similar to dropping the clutch too fast on a 5 speed. I was thinkin maybe fuel filter or timing but it revs perfect and we set timing?? What else should i check??
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Mar 2009
    796
    Does it die as soon as you put it in gear?
    If no codes, I'd be suspecting the torque converter.
    State College, PA
    3,552
    No it doesnt die... You can drive it but its reaaallllly bad. Torque convertor as in somehow installed wrong or as in need a new one?
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Mar 2009
    796
    Now that you've elaborated it doesn't sound like the converter.
    Take it to Auto Zone or Advanced and have them read the computer codes.
    Or you can buy the diagnostic tool for about 50 bucks.
    State College, PA
    3,552
    Quote Originally Posted by PaceFever79 View Post
    its not even driveable at this point. its like you're in a 5 speed just idleing then you drop the clutch and it bucks and just before it stalls you press the clutch in to save it, then you drop it again, then repeat. its bad hahah
    but like i said in neutral or park it revs perfect, idles perfect, no surgning, sounds like the timing is dead on. once its in gear its all screwed up
    and its a bone stock 5.0...no bolt ons, no cam, no intake, nothing.
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Mar 2009
    796
    It's probably one of the sensors.
    You need to read the computer with one of these.
    autozone, advanced, pep boys, even harbor freight sells them.
    Mar 2009
    796
    You should also test the fuel pressure.
    State College, PA
    3,552
    Ill try pullin codes and checkin fuel pressure and see wat i find
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Member silvernotch's Avatar
    Bethel Park
    664
    might sound odd but is the spout connector plug in? had a buddy that forgot to plug it in,idled fine soon as he put a load on it stalled would run for s##t.
    Petersburg,PA. 16669
    816
    Quote Originally Posted by silvernotch View Post
    good point and what u set timig at?
    88 GT...and some boost
    State College, PA
    3,552
    yeah its plugged in...definitely easy to forget though
    Quote Originally Posted by 349Stroker View Post
    just at the factory 10*...maybe ill try advancing it a little
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Sep 2007
    Dayton PA
    3,795
    had the same problem with a MAF sensor before
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    State College, PA
    3,552
    Quote Originally Posted by 92306gt View Post
    what computer is in the car? if you have another to try, id try that.
    its the factory computer from a '90 auto...i didnt look at it but im guessing its an A9P. im gonna try a few smaller things first then maybe try throwin a new ECU in
    i was thinking this is a possibility. im gonna try the fuel filter first and start small before tossing in a new mass air.
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Sep 2007
    Dayton PA
    3,795
    dont you have a spare off your car you can try?
    01 cobra: traded
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Don't you have a Moates QH, can't you just datalog the sensors?
    89 Vert, Stock block, H/C/I , DIY turbo kit MPT70 , Tweecer RT, C4 trans. 17 lbs boost. 3400#s - 10.3 @ 136 mph.
    Dyno Jet - 542 RWHP / 545 RWTQ
    State College, PA
    3,552
    Ya ive been tryin parts off my car... We put a new fuel filter in and tried using the coil and mass air meter off of my car that i know work but had no luck
    Quote Originally Posted by Black Vert View Post
    I have a QH on my 87... The car having issues is my dads '90.. Its almost bone stock
    After timinig it better it now is drivable. But when you hammer it it starts cutting either fuel or spark it seems like... Ill try pullin codes tomorrow. I think its an electrical issue
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    1,220
    How old are the tune up parts? Is there an air leak (Torn boot ?) between the MAF and the throttle body? Is the actual fuel pressure good? Distibutors have also been known to cause odd problems also.
    LowHill
    2,679
    Put a fuel pressure gauge on it that you can watch while you drive it
    Mar 2009
    796
    If it runs better with more initial advance that could still be a faulty sensor
    not telling the computer to richen ... TPS, MAF, MAP, fuel pressure.
    Personally, I think it is a lean bog. Need codes!
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Find anything out yet?
    2014 M235i (wife's)
    1964 Ford F-100
  1. 60 year old that runs 11's
    By 2000GT in forum Pictures & Videos
    Last Post: 01-12-2013, 02:28 PM
  2. Rough Idle and Code p2197
    By map22 in forum SN95-New Edge
    Last Post: 10-20-2011, 09:26 PM
  3. 1500-2000 RPM running rough
    By venom in forum Fox-SN95
    Last Post: 06-20-2011, 10:06 AM
  4. Rough night
    By travj31 in forum The Bar
    Last Post: 08-28-2009, 07:14 PM
  5. rough idle
    By 89 vert in forum General Tech
    Last Post: 07-23-2007, 09:48 PM
