Results 1 to 20 of 35
Thread: Turbo 427 NA engine dyno guess
    never stock biminiLX's Avatar
    Beaver
    2,406
    FINALLY this thing will be on the dyno Sunday for NA break-in with a carb.
    Here's the combo:
    427" SBF using following parts:
    FRPP SVO W-351 4-bolt block 2.75 mains
    4.125 bore custom Diamond turbo pistons tool steel .927 pins Hellfire rings
    4.00 stroke (mystery forged unit but a very quality piece--guess is Bryant)
    6.20 Lentz steel rod 2.0 journal ARP 2000 bolts
    9:1 compression/Cometic head/intake gaskets
    240cc TFS HP heads from Ed Curtis FTI 8mm 2.08/1.6 valves (EV8) with PAC LSx small diameter springs/Ti retainers (look awesome)
    Edelbrock Glidden Super Victor 4500 intake converted to EFI with port matching plenum blending
    Probe 1.7 shaft rockers
    Smith Bros. 3/8" .116 wall pushrods
    Custom billet core hydraulic roller cam from Ed 238/244 on 115 .600/.600
    Morel link HR lifters
    Melling select HV pump
    Stef's custom oil pan
    ATI balancer
    JW wheel
    Engine will be dyno'd with injectors plugging bungs and using a 1050 Dominator carb (to fit intake).
    Doing this to make sure rings are set and everything pulls clean over 7000rpm.
    Last version of this motor was more mild (CNC Vic Jr heads/Vic Jr intake/sl. smaller HR cam) and made about 520s/520s break-in without power tuning and was done by 6200.
    Will be using same builder/same calibrated Land & Sea engine dyno and have old dyno sheets to compare.
    I'm looking for 600hp NA and clean pulls through 7200rpm.
    So, what are your HP/TQ quesses?
    I will send a small prize if someone gets exact HP.
    Should have vid and pics next week.
    Wish me luck, haven't had much so far with this rebuild.
    Good luck with it!
    I'm guessing 587 HP on the break in carb (assuming it pulls out there).
    592 hp!
    2011 Mustang GT Kona blue
    2002 F-150 FX4 true blue, with Lightning blower swap
    2004 F-150 FX4 forged bottom end, built trans, Street Lethal Performance 76mm turbo kit, Black, Gray Leather, 6"susp, 3"body on 37's
    Let us know your parts needs we will work to beat any price!
    (724)964-8419
    9am-5pm M-F
    In house chassis dyno
    South Hills, PA
    4,052
    wish I could go, 579 hp @ 6800
    608hp / 622tq
    Have fun!! Can't wait to see the pics and VIDS!!
    I don't think it will make power at 7k with that cam....
    574hp @ 6600
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    599.9999999999999 hp
    If You Wanna thedak's Avatar
    Jul 2008
    DMB
    570 @ 6500
    Jun 2007
    2,108
    I'm saying who gives a damn, lets see what it runs like at the track when its done!
    tru dat
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    626@6600
    2014 M235i (wife's)
    1964 Ford F-100
    Beaver
    2,406
    Made 548.8hp@5800 and 540.9@5000 with poor power pulls.
    On the only 7000rpm pull we made it made within 4hp from 6100-6900rpm.
    Not that it was unexpected, but 9:1 compression and a small cam does not like a large intake and an 1150 Dominator.
    The dyno A/F guage broke earlier in the week and the engine never really loaded well and was lazy likely due to poor carb signal.
    Good news it is broken-in and had no problems, but not very productive from a data standpoint.
    I'm a bit disappointed because I suggested to the builder early on that we probably should have a 4150-4500 adapter to run a smaller carb but that was ignored.
    I guess if I wanted to know true NA numbers, I needed a regular SV and a 4150 carb, but in the end, it is built for a turbo and it better be good for that, I am confident it will be.
    I'll get some pics and a vid up later in the week, its been a long day.
    Beaver
    2,406
    550hp on 9:1 with 427 cubes is still a nice piece for sure....I think the dommy would make more peak power than a 4150 unit....
    The good news is that the engine seems to be in correct working order after the break-in.
    Beaver
    2,406
    A well tuned Dominator I would have thought too, but this 1150 unit was originally built for a 13:1 570" motor, maybe it was just too big. The 1050 unit he had was a mystery piece, we did put it on for the one 7000rpm pull and it was down on torque from the 1150, but the HP still peaked around 5800 but held that peak close to 6900.
    It was weird, basically the dyno would load the motor and just the velocity and cam signal wasn't there yet so it would struggle and then take off but still not a clean pull.
    Overall everything is fine, just disappointing not to see the engines true power potential NA. But, that is more time/money/borrowed parts for a moot point.
    Its a turbo engine and should love boost.
    Getting delivered to Street Lethal today and the turbo will be there by the end of the week.
    Eh, it's broke in, didnt make a mess on the dyno, and it's ready to go in the car ... lets see the boosted numbers and I think you will smile ;)
    Beaver
    2,406
    Yeah, by disappointment I guess I just mean I like as much data as possible and to spend the money on a dyno break-in but not get true power capabilty wasn't what I was hoping for.
    This makes up for it though---baddest cast 88 available:
    http://www.workturbochargers.com/ind...mart&Itemid=53
    Being shipped out from Reed to Street Lethal today, last of the pre-production units made. We went with the 1.0 housing as it should make the best average power 4000-7000rpm, which should be the launch to trap range
    robinson
    1,091
    truth!
    but here is my guess!
    /twocents
    robinson
    1,091
    whoops didn't see this happened already. still damn stout numbers though. but dynos are heartbreakers. besides with low compression that is fantastic IMO. the important goal was to break motor in. just worry about the end goal don't look and scrutinize everything. i had a motor that made 300hp on 8psi. with low compression. once we turned the wick up it came to life. 18psi got the motor a hhair shy of 700. i know peanuts in comparison to this build but same concept.
    /twocents
    Beaver
    2,406
    Quote Originally Posted by bgblockelcamino View Post
    Thanks man, totally agree.
    Depending on timing of things, I'm hoping to make an NMCA event or 2, maybe see ya there
  1. Engine Dyno
    By Wolfpack Speed in forum Pictures & Videos
    Last Post: 09-26-2013, 07:00 AM
  2. Turbo 427 rebuild
    By biminiLX in forum Fox-SN95
    Last Post: 04-01-2012, 01:45 PM
  3. Engine Dyno
    By Flyin Monkey in forum Fox-SN95
    Last Post: 09-20-2010, 10:33 PM
  4. Spec 3+ clutch vs. Turbo 427
    By biminiLX in forum Pictures & Videos
    Last Post: 01-02-2010, 09:33 PM
  5. Guess my dyno HP
    By RUSH2112 in forum The Bar
    Last Post: 10-02-2007, 09:03 PM
