Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Turbo 427 NA engine dyno guess
  1. #21
    never stock biminiLX's Avatar
    Beaver
    2,406
    F**K the NA numbers anyway ;) :
  2. #22
  3. #23
    Apr 2009
    Allison Park
    538
    Damn J,
    You trying to start a wind tunnel testing facility?
    Randy
  4. #24
    Wow, Nice turbo :D
  5. #25
    So with that beast on there, what is she going to run... 8's???
  6. #26
    Beaver
    2,406
    It better fkn go 8s every time out, unless I forget to turn on the boost controller, then high 9s are acceptable :D
    Honestly with this turbo, the RPM potential of the refreshed motor, and the ability to run 315/60/15 tires (those big bastards will help big time on marginal tracks), the only questionable link is the built AOD. If that holds, it runs 8s----if not it gets a powerglide ;).
  7. #27
    Beaver
    2,406
    And thanks Randy and Bob, I hope the Street Lethal guys post a few more turbo pics. I had to run and only got those cell pics, made my day it was delivered just before I got there and I was very impressed with it.
    I've heard a guy in Michigan has a program to take almost 30# out of it for $300, that will probably be a future plan.
  8. #28
    Jan 2008
    Jefferson
    4,674
    why did you go with such a small turbo??!?!?
  9. #29
    good lord what did that thing weigh
  10. #30
    Beaver
    2,406
    To keep the ability to run x275 and classes where the car could be restricted to 88mm. I'm moving close to Milan, MI and they have a class that would be fun that is 88mm max. and this is the best 88mm turbo available except for billet wheel $3000+ dollar deals.
    Not building this for any class other than True Street and my demented definition of a streetable track car.
    The motor could support a bigger turbo but I wanted to keep the rpm range and cam smaller and this turbo has supported 1700hp in testing, should be enough
  11. #31
    Beaver
    2,406
    Quote Originally Posted by pwtmxracing View Post
    Shipping weight was 67# :( , about 11# heavier than the old GT4788.
    There is a lightening program available, 30# for $300, actually reasonable if you're a class car.
    It really is a big piece, gotta get a pic next to a pop can.
  12. #32
    robinson
    1,091
    that turbo is a bad bitch. the BW stuff is hard to beat. making a kit for a car in next couple weeks using a smaller version. impressed with how heavy it is!
    /twocents
  13. #33
    Beaver
    2,406
    I hope it is and performs like I've been told.
    I got it from Reed at Work Turbo (formerly Supernatural Turbo).
    He's worked with some top racers and locally with Street Lethal on a few projects, awesome guy to work with if you need a turbo.
    He did a lot of testing for BW on these new AirWerks designs, supposedly this same 88mm made 1700hp engine dyno on an 8000rpm 30# 370 SBF!
    This was the last pre-production unit available from BW, should almost be available to public now.
    What's the turbo/project you're working on?
  14. #34
    great looking turbo , how do they get the weight off ? by pollishing the cold side ?
  15. #35
    robinson
    1,091
    i will be using s475 on a stock ls2 GTO. did Garret gt4202 on a 02 camaro last couple years. haven't really messed with any turbos larger than 76mm. more street oriented and try to keep customers on conservative end of things and not chase a number
    /twocents
  1. Engine Dyno
    By Wolfpack Speed in forum Pictures & Videos
    Last Post: 09-26-2013, 08:00 AM
  2. Turbo 427 rebuild
    By biminiLX in forum Fox-SN95
    Last Post: 04-01-2012, 02:45 PM
  3. Engine Dyno
    By Flyin Monkey in forum Fox-SN95
    Last Post: 09-20-2010, 11:33 PM
  4. Spec 3+ clutch vs. Turbo 427
    By biminiLX in forum Pictures & Videos
    Last Post: 01-02-2010, 10:33 PM
  5. Guess my dyno HP
    By RUSH2112 in forum The Bar
    Last Post: 10-02-2007, 10:03 PM
