Results 1 to 17 of 17
Thread: Stick Shift Carange
    Stick Shift Carange
    I had a little oh..... incident last Saturday night ... Was in the semi final round at PRP, car launched and made a little off squirm ... not so unusualy for my car to to that at times, but this was more odd ... pulled 2nd gear and the car wanted to swap ends.
    Broke the bolt for the lower control arm ... The only thing that kept it from coming out was the bolt head hitting my muffler ...
    It also let the housing move enough to smack my passenger side shock and dent the tube enough the piston is stuck and let all the oil out of it.
    It's all fixed now, we welded everything again, added some support ... raced the car today and it hooked hard (1.60 60's) and most important went straight. New arms have greasable front bushings and QA1 heims on the housing side. Need to inspect them more often for sure.
    Jun 2007
    2,108
    More RPM might work.
    Castle Shannon
    1,276
    wow, i'd be looking my torque boxes over real good..
    torque transfer > 10.8 sheer strength :beer:
    SexyManBeast KeystoneJohnny's Avatar
    Irwin
    888
    DANG! I can't believe it let loose like that. Way to go Bob.
    Toys:
    2013 Ford F-150 FX4 4x4 C.C.
    2010 Kawasaki Z1000
    Somerset Co.
    2,907
    Cool... Broken rear end parts
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    Glad to see you got your parts and are back up and running again.
    2019 Hellcat
    Mt.Pleasant pa 15666
    2,832
    Wow .that could of been bad!
    Mar 2009
    796
    Impressive!
    Glad the carnage wasn't worse, and that you're all fixed up and ready to go.
    Thanks everyone!
    Clearly going too easy on it ... more is always better ;)
    We was over them soup to nuts. The torque box on this side was a little frigged up ... We was able to push it back into place with a porta power, reweld everything, and made plates to back up all the holes where the bolts pass through, then added additional support.
    I will say, the "battle box" re enforcements on the outside mostly saved everything by keeping that hole in tact and in place, gave us a point to work from to fix everything else. The hole on the frame rail side was pretty beat up.
    The good news is that both lower arms are the set at the same length and the rear checked out square under the car ... I raced Saturday and it hooked and went straight so we definately got it back in the right place. Nw everything is beefed up and ready to go again :D
    Dang Bob. I've bent the front bolts but never broke one.
    Good job
    I aim to please Ed :)
    Quote Originally Posted by Mater View Post
    x2...glad to hear you lucked out on this one Bob.
    Belle Vernon
    1,294
    Man Bob... are those grade 8 bolts?
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    never stock biminiLX's Avatar
    Beaver
    2,406
    Glad its back together Bob.
    You're continued dedication to break parts is impresive :)
    I have also never heard the expression soup to nuts ;)
    Yeah, it could have been VERY ugly. Lucky for sure.
    The bolts that came out came from CHE and are not marked for grade. I am going to hardness test one of them here at work and try and estimate. The bolts are actually a Metric equivalent, and what went in are 12.9 spec
    LOL, lots of hard launches on them over the years. This car makes a lot of passes, but I would be happy to not keep looking for weak links.
    Not enough of hunky in you or something ... Figured you would of picked up on the language anyway ;)
    Those bolts weren't marked? I would throw those out without thinking twice for any high load use. Standard threads bolts unmarked are Grade2. Think all metric are marked even 8.8's
  1. Learning to drive a stick shift
    By Minstang in forum The Bar
    Last Post: 07-05-2011, 10:42 PM
  2. Whats up with the stick shift thing at PRP
    By mustang50lx in forum Drag Racing
    Last Post: 03-26-2009, 07:49 PM
  3. UMTR (Stick shift drag racing)
    By Martin0660 in forum Drag Racing
    Last Post: 10-09-2008, 09:23 PM
  4. This one is for all the Stick Shift Warriors on here
    By Sonic03snake in forum Drag Racing
    Last Post: 05-22-2007, 08:30 PM
  5. 2 new 13.0 stock LS-1 stick shift vids
    Last Post: 03-31-2007, 04:59 PM
