Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: Finally, I'm making progress again! DUW!
    As most of you know I over-rev'd my engine in April 2005 at the SSOTN Spring Nationals at Cecil County Dragway and bent all of my exhaust valves. This was a result of a 3-2 shift which by my calculations sent the shortblock to around 8300rpms! OUCH! Anyway, its been nearly two years and I've made a number of purchases, but I have a ton more to do. I had a buildup thread here before the site crashed, but until now I haven't really done anything new to start a new one. Well, spring is here and the car needs to be running ASAP.
    Here's what I already have done:
    • -Dart 8.2 Sportsman Block
      -Scat 4340 forged crank
      -Scat 4340 forged H beam rods with ARP 2000 rod bolts
      -JE/SRP forged pistons
      -Internally balanced rotating assembly
      -Powerbond SFI balancer; 0 balance
      -Fidanza SFI aluminum flywheel, 0 balance
      -Clevite 77 main bearings
      -Clevite 77 rod bearings
      -Childs and Aberts rings
      -Crane Cams billet timing set
      -FMS billet steel blocker plate
      -RNH Performance oil system package consisting of:
      -Melling M10688 oil pump
      -ARP chrome-moly oil pump shaft
      -Canton 7qt oil pan
      -Holley Systemax Intake
      -AFR 165 60cc pedestal heads with lightweight valve springs/retainers
      -My old FTI custom cam
    The heads are going to the machine shop this week to have a valve job done and then I will reassemble them and put them on the car. I'm only temporarily going to run these 165's. They will eventually be pulled from this shortblock and will go on my '90GT along with the rest of my old combo. I am outfitting them with a cool valvespring/retainer setup though and I will post up pics when they are done to see if anyone can tell what I did.
    My '90GT that will be receiving all of my '95's old parts: (it looks rough but the interior and underside are spotless!
    My 17X9 Bogart wheels that fit perfectly with my stock front suspension ended up having clearance issues with my PA racing tubular setup and coil overs due to the BS I had selected for them. Since these wheels are a true 3 piece design, I am getting a new back half for the wheel to cut out 1" of BS and thus making it a 17X8 wheel. This should clear up my clearance issues and my 245 series tires will not look as stretched either on the smaller wheel.
    I have a new Cervini's stalker front bumper, ABC exclusive saleen style side skirts, a MPS saleen style heat extractor hood, and a 1 of 499 cobra hardtop for my car. I still need to purchase my saleen rear bumper and when I do the car will be repainted and the new body kit will go on.
    If I can swing it, a 6pt bar will also be going in the car.
    Today I set in an old block along with my holley intake to see if the intake will clear my hood with a 3/8" spacer... thankfully it does!
    That's it for now, I'll keep updating this as things get done.
    803
    Thats awesome Paul,good luck with the build.
    cool now only that block in the car was the DART.you wold be that much closer
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Looks great paul!
    Lookin good man. Where did you find one of those hard tops? Seems like that would be a pretty tough piece to track down.
    I can just imagine what that set you back!
    Thanks guys! I'm excited and overwhelmed at the same time thinking about getting this running again!
    I told me wife years ago that if I ever came across one that I'd do everything I could to get it. I was on ebay one night and came across it, and it was for local pickup only. It was right around my birthday and I basically asked everyone that would normally get me something to help chip in so that I could get this top. I paid a decent amount for it, but not no where near what I've seen some of them go for. The head liner is pulling away from the sides in the very back, I think it just needs re-stretched and glued. Other than that its flawless. Its heavy as hell though, I bet it goes a good 125-150lbs. DOH! Just what I needed... more weight to my already portly 'vert! The only reason why I bought it was because of its uniqueness. I love being able to drop the top and the top will be down more than this will be on, but I plan to never sell my car and when I had the opportunity to snag one of these very rare pieces I did. Plus, if and when I have my daughter in the car I think the hardtop will be a plus from a safety and "fumes" standpoint. LOL!
    Here's some pics of the hood and hardtop on the car:
    And here's the new front bumper, I can't wait to ditch my old kit for these new pieces!!!
    Nice find man . Not too many yellow hardtops running around, that's for sure.
    Im glad that your gettin back to "Get er done" mode, I wanna see this thing on the road its been way too long!!
    This is truely going to be one of the nicest, fastest, overall cars on the road once you get everything done.
    Member BoneCrusher's Avatar
    Murrysville
    882
    Awesome Paul! I love that hood man. Can't wait to see you running again.
    Mike
    boats n hoes fork5o's Avatar
    Hopewell
    833
    thats awesome. it gonna be so sweet when its all done.
    -Joe
    1995 5.0
    The Car
    Member 2000GT's Avatar
    Plum, PA
    1,612
    i am looking foward to seeing the finished project. It looks great so far! What is your ETA for it's debut?
    Thanks again guys, I can't wait to get this thing done!!!
    Sean, its really hard to guess as an ETA as I haven't even contacted anyone yet about paint, but if all things work as planned the heads will be done and assembled in no more than 3 weeks. At that point the motor goes in, and it should be ready to run for the first time in 2yrs which is a BIG step in the right direction.
    I got some parts today to help me with the heads. Here's my new 7* locks and valve seals:
    I also picked up a blast cabinet from Harbor Freight as I got tired of never being able to find a shop that could do small parts for me. I hit one of my stainless steel FMS headers today with some glass bead and below is the results. I plan to powdercoat them with some high temp. coating I bought from eastwood a while back. We'll see if it holds like it claims, they say its good to 1000* and they market it for use with headers:
    Got Boost?
    West Mifflin
    1,442
    Looking good man. Cant wait to see that thing back on the road and the track.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    My Dad has used that stuff on a set of manifolds for his 56 Desoto. It holds up real well.
    out in the woods
    4,948
    awsome man... gonna look sweet..
    That's good to hear Ed. I've never known anyone else that has used this before and I was a little leary about it. Oh well, they will only be on the car for a year or so anyway then my swain coated ones will be on that face forward!!! :)
    Senior Member 6987stangs's Avatar
    VALENCIA,PA
    687
    LOOKS GOOD
    Mt Pleasant, PA
    4,905
    Lookin good Paul!!! The top is cool, the best of both worlds.
    4,321
    looking good paul, good luck with everything!
  1. Making some progress
    By Cam99 in forum Pictures & Videos
    Last Post: 02-06-2012, 08:54 PM
  2. My '94 Cobra project has finally begun... DUW
    By Killercanary in forum Fox-SN95
    Last Post: 02-18-2009, 09:29 AM
  3. Progress on my 01 Gt
    Last Post: 06-10-2008, 06:30 PM
  4. Project Fox232 making progress.
    Last Post: 06-09-2008, 08:30 AM
  5. Finally some progress
    Last Post: 04-07-2007, 10:08 PM
