Results 1 to 12 of 12
Thread: coolant leak help !!!
    Member Warrior1670's Avatar
    Oct 2010
    Cranberry Township, Pa
    97
    Exclamation coolant leak help !!!
    Ok, so after driving the stang and I park it, I can smell antifreeze. I can't find anything leaking anywhere. I've checked the heads, hoses, anywhere I can look. There's nothing on the ground and no sign anywhere. The low coolant light has come on two times, once yesterday and once last fall so the leak isn't too bad. There's nothing in the oil. I doubt that it is leaking into the cylinder because I'd expect to smell something if the motor was running, not if it's off. The smell is definitely coming from under the hood.
    Any ideas? I'm pulling the plugs tonight but other than that I'm stumped!
    Brookline
    2,897
    Try a pressure test to see if it's coming out anywhere? It could be burning off before you see it drip anywhere.
    Oct 2010
    97
    Will that point to the leak or just show there is a leak?
    Brookline
    2,897
    Well hopefully it will do both!
    May 2011
    washington pa
    82
    check to see if your carpet is wet on the passenger side. might be your heater core leaking.
    Oct 2010
    97
    Anyone have a pressure tester that's willing to lend it? I called Advanced in Cranberry but they don't have one.
    Belle Vernon
    1,294
    Quote Originally Posted by jasons_98gt View Post
    x2 or turn on the defrosters when the car is warm and you my get moisture or a film on the windshield.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    Oct 2010
    97
    Thanks guys. I found a leaky radiator. All the fluid was dripping an running down into the bumper so nothing ever hit the floor. There must be a real small hole somewhere cause there's just one small spot that seems to seep.
    I drove the car home in a fun manner yesterday to keep it hot so I could jack it up and crawl under.
    Brookline
    2,897
    Glad you found it, and glad it wasn't something more serious (HG).
    Oct 2010
    97
    Lol, if it was a head gasket, that would just mean a call to Mr. Edlebrock or someone else that knows a few things about flow!
    I'd almost rather it be a head gasket than a heater core - if the SN95's are as much as a bee-yotch to change as the fox bodies are...
    Glad you found the leak - I hate that smell...
    Oct 2010
    97
    Me too. I had to change the evap core in my 2000 dakota. That was a bitch. I had to take the whole dash out, remove half the interior panels to get the dash out. Then I couldn't get the dash back in. I also created a nice vacuum leak that I never did find. NO MORE DODGE!
  1. Help, coolant leak
    Last Post: 03-21-2011, 05:26 PM
  2. Fuel Leak
    Last Post: 03-26-2009, 01:25 AM
  3. Does this look like a vacuum leak?
    Last Post: 09-11-2008, 06:41 PM
  4. Major coolant leak...
    By 99 GT Coupe in forum SN95-New Edge
    Last Post: 07-26-2008, 05:26 PM
  5. Exhaust Leak
    By hunter31 in forum S197
    Last Post: 11-16-2007, 11:13 AM
