I have a 351W roller motor. I have everything to put a 351w into a fox except the heads and cam. The motor is disassembled with brand new speed pro pistons ( block will need bored 30 over for the new pistons and cleaned if you want a clean motor ). I have a complete fel pro high performance gasket set, new oil pump, timing chain. I have a lower intake polished that is for a edelbrock performer upper or typhoon upper. 30 lb injectors, 70 mm throttle body/egr spacer. The ford racing oil pan for fox brand new with pick up and dipstick. The accessory bracket for power steering. I have two sets of E7 heads one off a 302 and other set off a 351 you can have with it all. Everything is new except block, crank, rods. Moving and do not have time to finish and do not want to take it all with me. 2247156187. i am in the Butler area north of Pittsburgh. Shoot me an offer just need it gone.
