Results 1 to 15 of 15
Thread: Anyone with a 87-93 Vortech setup that I can check out?
    Member raynist's Avatar
    May 2009
    Pittsburgh (Upper Saint Clair)
    27
    I currently have a Kenne Bell 1.5L on my 89 GT with Heads/Cam/Intake/3.73 Gears and a TKO600 running 8 psi. I am thinking of switching to a Vortech around the same boost or maybe a bit higher. I am afraid that I will miss all of the low end torque of the KB. Does anyone have a mild Vortech that I can ride in or take for a test drive to see if it is something I want to pursue before dropping $3k?
    I live in the south hills but work in Wexford.
    Thanks!
    Ray Nist
    1989 GT
    Kenne Bell 1.5 8psi
    Comucam 2040 Camshaft, Boost-a-Spark, C&L Tube, MAC Prochamber, 255lph Pump, AFR 165 61cc Heads, 42lb inj and 1.6 rockers
    TKO-600 Transmission
    Findaza Aluminum Flywheel
    You are going to lose some bottom end.. But you will kill that Kb blower on the top end.
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Yeah, at 8 lbs you would be around 400 at the wheels.
    2014 M235i (wife's)
    1964 Ford F-100
    Member silvernotch's Avatar
    Bethel Park
    664
    my son lives in st.clair he has an s trim on a 331 stroker putting 13lbs got 516 at wheels. cant keep the damn thing on the road when it hits boost.
    More Power to Come! Stroked03Cobra's Avatar
    Kittanning/Butler
    1,055
    I know your looking at just the vortechs, but I had the Procharger P1-SC on my old fox at 9.65lbs did 495 at the rear on a dynojet. Got to love the sound of a centri!
    2003 Sonic Blue SVT Cobra - 711 RWHP @ 671 TQ @17psi. Kenne Bell 2.8, FRPP Modular Boss 5.0 block, Big Bore 324ci, with full stroker kit, JDM Stage 3 Heads, Custom Grind Cams and alot more. 4,900 original miles..... Currently at Street Lethal Performance for a makeover!
    1997 Mustang GT - 5 speed, 34k original miles
    1968 Fairlane GT - 302ci Hurst 4 Speed
    1999 Crown Vic - P71 Clone, JLT CAI, Dual 40 Series, Daily Driver
    My vote is for Paxton.
    1967 camaro
    86 t-type
    May 2009
    27
    How much boost could I run safely without using meth or an intercooler?
    If I go with a 10-12 psi system will I see any boost at 2500-3000 rpms?
    Who is a good vortech tuner around here?
    1989 GT
    Kenne Bell 1.5 8psi
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Screw that, put a turbo on it
    89 Vert, Stock block, H/C/I , DIY turbo kit MPT70 , Tweecer RT, C4 trans. 17 lbs boost. 3400#s - 10.3 @ 136 mph.
    Dyno Jet - 542 RWHP / 545 RWTQ
    LowHill
    2,679
    Or even nitrous
    How are you guys keeping your stock 5.0 blocks in one piece long-term while making around 500rwhp ?
    Trafford, Pa
    2,308
    Long-term? They aren't. Although I ran an entire hillclimb season with a T-Trim on a stock longblock. Some people just get lucky. Went12s made like 5000 hp on a stock short block or something.
    2014 M235i (wife's)
    1964 Ford F-100
    Ok - that's what I figured. I'm just not that lucky.
    LOL 5000 hp
    Trafford, Pa
    2,308
    LOL 5000 hp
    I was exaggerating. It made a lot. I will let him comment, but it was pretty dumb how much power it made.
    2014 M235i (wife's)
    1964 Ford F-100
    my stock short block has been together since 2001 making 500+ it makes about 12-15 lbs and is due for a new belt its all in the tune and not reving over 6200
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    540 at wheels for 6 years now. Definately keeping my fingers crossed.
    2015 GTPP
  1. Vortech s trim setup everything
    By chuck94 in forum Ford Vehicles
    Last Post: 01-04-2014, 03:26 PM
  2. WTB: Saleen, Saleen/Vortech, or Vortech intake
    By Black87GT in forum Ford Parts
    Last Post: 09-01-2013, 09:04 PM
  3. Replies: 1
    Last Post: 04-25-2011, 07:22 AM
  4. Guys with Vortech Blow thru Setup.
    By Projectcobra97 in forum SN95-New Edge
    Last Post: 11-20-2009, 05:22 AM
  5. check out this setup
    By 92306gt in forum The Bar
    Last Post: 08-21-2008, 12:04 PM
