Thread: 93 Cobra with SN brake swap. Loud squeaking!!!
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Hey guys-
    I recently did a 95 cobra brake swap on my 93 cobra. The one rear caliper is squeaking like a mofo. It's actually louder than the vortech if you can believe that. Hit the brakes and the noise goes away....release the brakes and the noise is back.
    This evening I put the car on stands, started the car up, put the car in 4th and listened for the noise....nothing. Took the car around the block and the noise is still there. Ugh.
    I have the anti-moan brackets installed, all the parts are brand spanking new, and the car feels fairly good besides the noise.
    Ideas?
    2015 GTPP
    Senior Member celeste's Avatar
    Uniontown, PA
    276
    There is a guy over on stangnet.com that goes by the username Mustang5L5 with a lot of knowledge on rear disc swaps. When I was doing my rear NRC disc conversion he was a ton of help. Maybe pm him and see if he has ever experienced anything.
    http://www.fquick.com/celeste
    1989 Mustang GT 663 RWHP
    MM&FF May 2010 Cover/Feature Car AND 5.0 Magazine Oct. 2011 Feature Car
    1991 Strawberry Notch
    2003 Cobra White with Parchment inserts (1 of 170)
    1992 Calypso LX
    2008 Roush Blackjack #30 of 100
    MM&FF Article
    http://www.musclemustangfastfords.co..._gt/index.html
    5.0 Article
    http://www.mustang50magazine.com/fea...ble/index.html
    mayeb you need a differnt pad or silencer behind the pads?
    1,344
    I'm a dumbass guys...
    I swapped out pads lastnight, thinking that the "cheaper" ones I bought were the problem. Got the car back together and still had the same noise. Pulled the car back in the garage, jacked the rear up on the suspension, put the car in gear and the noise was there!!!
    Driveshaft was rubbing on some bracket....hence the metal on metal noise that I was hearing. Ugh.
    2015 GTPP
    I hear ya there. With my car, the problem usually is the loose nut behind the steering wheel as well...
    1,344
    2015 GTPP
    Quote Originally Posted by venom View Post
    Hey guys-
    Ideas?
    You should do what my step children do when they here a noise with the car. They turn up the radio
  1. Squeaking Noise - T5
    By 94Cobra in forum Fox-SN95
    Last Post: 11-06-2014, 07:37 PM
  2. Big brake swap for sale 99-04
    By mustang50lx in forum Ford Vehicles
    Last Post: 09-25-2011, 10:24 PM
  3. cobra brake pads
    By 94gt5.0 in forum Ford Vehicles
    Last Post: 06-11-2011, 01:47 AM
  4. Cobra brake conversion
    By dpl133 in forum SN95-New Edge
    Last Post: 05-21-2010, 10:08 AM
  5. Ticking and squeaking
    By 95DropTop in forum Fox-SN95
    Last Post: 04-15-2009, 10:31 PM
