Results 1 to 7 of 7
Thread: Computer help
Hybrid View
    Sep 2007
    176
    Computer help
    Ok, I decided to try and replace the LCD on a laptop. Looked it up on the internet and didn't look too difficult. I ran across these 3 tiny connectors, I think they're called ZIF connectors. I looked at them, thought I had them figured out and diconnected them. Before I know it I have these 3 little ends not connected to anything anymore. Am I screwed?? Can these be put back together??
    Member Warrior1670's Avatar
    Oct 2010
    Cranberry Township, Pa
    97
    Can you take a few pics and post them or email them. If the connectors are still attached to the PCB then you should be fine. The ZIF's should have a small little slider that pulls out (this varies by connector though), then put the ribbon in and push the slider back in. Pics would help though.
    Brookline
    2,897
    As long as you bought the right replacement LCD you should have the same connectors and everything should go back into place.
    I've replaced a few screens before in laptops, let me know if you need more help.
    Your best bet is to re-trace all the steps of what you disconnected (find the replacement instructions online) and then see where they go.
    Sep 2007
    176
    The connectors had nothing to do with the screen, one was the power botton and the others were the mouse pad.
    They're not coonected to anything now, when I disconnected them I slid them back out of the motherboard and next time I looked they were laying there. I'll try to get pix...
    Brookline
    2,897
    Quote Originally Posted by torchred v6 View Post
    Well, then they need to go back to the power button and the mouse pad... If they have nothing to do with the screen then they go back to where they originally go?
    Get a manual and you'll see where they go back in.
    Sep 2007
    176
    First is the connector, second is where it used to be. Question is can I put this back together?
    Brookline
    2,897
    Just buy a new one. Or if you goto a mom and pops computer store they'll probably give you one.
  1. Replies: 4
    Last Post: 01-30-2010, 12:03 AM
  2. 94-95 Computer
    By 955.0 in forum Fox-SN95
    Last Post: 05-16-2009, 10:00 AM
  3. need a computer 99 gt
    By ocracing in forum Ford Parts
    Last Post: 06-04-2008, 08:14 PM
  4. PE Computer
    Last Post: 02-20-2008, 08:59 PM
  5. Computer Help
    By RUSH2112 in forum The Bar
    Last Post: 11-21-2006, 10:58 PM
