SOLD!!!!!
Hi, I took the Kenne Bell off my Mustang and I'm selling it complete.
This the kit for a stock 5.0 no bigger injectors or fuel pump is needed. Comes with the FMU. If you want to run bigger injectors and fuel pump you can, Just don't run the FMU when you do.
This was the 1.5 set up until last summer the 1.5 blower unit was replaced a with a fresh 2.2 blower that was rebuilt by Kenne Bell.
Right now it has the 5-6 lb pulley on it and it boost 5-6 lb no problem.
This does not come with the flowzilla or blowzilla manifolds. Just stock Kenne Bell manifolds. It comes with 2 smaller pulleys just in case you want more boost. It also comes with the Kenne Bell tool for changing the pulleys, Some Red line oil, The cold air intake (it's the one in the pictures) The instructions that came with it. And the bracket for the Air conditioning.
This set up is for the stock intake. If you need a stock intake for an extra $50 you can have the one that I was running. It will come with the stock injectors, wiring harness, EGR plate, and throttle body. I have a new belt that was an extra comes with that too.
I'm sure I have some other stuff for it I no longer need.(it will come with it)
The price is $1900. That not where negotiations start that is the price.
