Thread: Fueling question..
    Senior Member RogerStout's Avatar
    Jan 2011
    Lumberport WV
    281
    Fueling question..
    Hey whats up guys, I have been working hard as of late to get the mustang road worthy.. Well its not totally done but its on the road.
    Got a quick question, I got the car from a kid that didn't know much about it and it has been all kinds fun funding all the mods to the car.. Huge amount.
    Here is where the questions comes in. The motor appears to be 302 out of a 99 explorer due to EV6 injectors. gt40p heads that are stock for that motor. Only real mods I can see is Cobra Upper intake 70mm TB CIA and mac shorty headers. with that said the 19lb injectors (stock) are working double time to keep it fed. I have to run 50psi at the rail just to keep it from going lean. I do know it has 1.72 RR but with such little in the way of mods why is this motor so hungry? I considering putting in 24lb injectors but holding off for a spring time SC install.
    Does that sound normal? From some reading the 19's should be good for 300hp but even at 50psi I still get lean codes on occasion..
    wvstreets.CO
    Jan 2011
    Lumberport WV
    281
    Just incase I missed something here is the official mods list.. what I have found so far.
    Cobra Upper Intake
    Gt40 Lower Intake
    GT40P Heads
    BBK 70MM TB
    Scorpion 1.72 Roller Rockers
    MAC CAI
    MAC Shorty headers
    Under Drive Pulleys
    UPR X Pipe (2.5")
    Mac Pro Dumps
    RAM HDX Clutch
    MGW Billet Shifter
    Fiore Billet Aluminum Clutch Quadrant
    Fiore Firewall Adjustor.
    Maximum Motorsports Full Length Weld-ON Subframe Connectors
    Maximum Motorsports Extreme Duty Lower Control Arms with Spherical Bushings in Both Ends
    Maximum Motorsports Panhard Bar w/ Polished Arm
    Maximum Motorsports Caster Camber Plates
    Eibach Pro Kit Springs
    Tokiko Blue Shocks
    18" FR500's 9.5" in front with 275/35/18 Nitto INVO and 10" in the rear with 305/35/18 MT ET Street Radials in the rear.
    2000 Cobra R Brembo 4 Piston Calipers w/ 13" Rotors and Goodridge stainless braided lines up front
    Ford Racing aluminum Driveshaft
    Corbeau LG1 Legacy Racing Seats
    Fiberglass Hood
    wvstreets.CO
    I would think 19's would be ok for that setup as I would guess it is a ~260rwhp setup. Fwiw I made 380rwhp with 24's na with 45lbs of base FP.
    Jan 2011
    Lumberport WV
    281
    So is it possible this motor is not stock internally because of the fact that the 19s are coming up short on the high end? also mine is untuned.. yours tuned? Probably wishful thinking on the internal mods but only thing I can think of that would explain the lean condition.
    wvstreets.CO
    Brookline
    2,897
    If the only things is rockers and rest is 99 spec 302 except the Cobra intake, I don't see any reason why it would need more fuel than normal. Maybe you should invest in a wideband and get it on the dyno? Especially if you are already guessing at the mods, maybe there's more going on than you think?
    Quote Originally Posted by RogerStout View Post
    When you say this, are you checking pressure while driving or just setting base? It sounds like you dont know what in it as far as pump, but it could be a fuel pump issue if you are setting base and not checking it at high RPM. Basically the pump will reach pressure at low flow, but can't keep up at high loads ... just a thought, I would check the pressure while driving.
    Jan 2011
    Lumberport WV
    281
    50psi at idle..Pressure gauge is under the hood.. I will take a look at the pressure under load.
    As for a dyno tune, I have some winter plans for the car so dont see spending the cash when I am just going to add a SC and have to get a retune.
    wvstreets.CO
  1. Ok I got a question
    By bill412 in forum SN95-New Edge
    Last Post: 04-28-2012, 03:59 PM
  2. T5 question...
    By FineLineMtrSprt in forum General Tech
    Last Post: 08-07-2011, 06:23 PM
  3. 94-95 Question
    By Stangman701 in forum Fox-SN95
    Last Post: 09-14-2009, 04:00 PM
  4. Another question..
    By Shorty429 in forum General Tech
    Last Post: 05-19-2009, 04:18 PM
  5. 94-95 VC question
    By 94svtcobra in forum Fox-SN95
    Last Post: 09-05-2008, 04:42 PM
