1994 mustang cobra "ROLLER" rio red ------- 3500.00 o.b.o (will entertain offers for quick sale)
black cloth interior ,no mach 460 from factory
the car is extremely light ....
upr pro series tubular k member
upr pro series tubular a arms
upr/eibach coil overs 14-130
mm caster/camber plates
strange 10 way adj struts
hurst line lock kit
abs deleted and new lines ran completely
upr pro series dbl adj upper/lower control arms
solid bushings
solid alum. spherical bushings in rear
lakewood 50/50 shocks
eibach springs in the rear
mm sub frame conectors w/ seat brackets
31 spline drag strange axles
31 spline center w/ carbon fiber clutches
long studs on all 4 corners
4.10 ford racing gears
255 intank pump
mallory adj fuel regulator
15x10 weld pro stars
325 50 15 bfg drag radials
15x 3.5 weld pro stars
165r15 tires
autometer monster tach w/ light
autometer fuel press/oil press/water temp gauge
aem wideband gauge in a pillar pod
battery relocated to trunk
battery shut off switch
no p/s no a/c
factory wiring harness ecu etc is there
fuel rails,sensors, radiator etc is all with the car
it has door dings and a few minor scratches but all in all its a nice looking car, and ready for a monster drivetrain , rear wing was deleted and deck lid holes welded and painted (wing is included with car though)
i know there is more there that i am forgetting to list almost all of this stuff is new with less then 40-50 miles
was an original 5speed car .. rear seats/belts etc are currently out of the car but they go with it if you wish to instal them again..
price is above and i will entertain offers for a quick sale . i am in altoona pa 16601, thanks
email ruthlessgsx@aol.com or text 814-207-3299
