Thread: Will a Fox strut fit through the strut tower hole ?
    Senior Member frankstang's Avatar
    Sep 2007
    Homestead
    780
    I can't break loose the bolt on the strut, so I was thinking about unbolting the factory caster/camber plates and just lifting the whole assembly upwards through the shock tower hole ? Will this work ?
    I'm installing a set of Bilsteins and MM caster/camber plates.
    On my SHO, my buddy put a 5 FOOT pipe ( yes five feet long ) over the breaker bar to bust the nut loose on the strut. He may have heated it up a bit beforehand as well. I couldn't believe how much force it took to do it.
    Should fit, but it is just as easy to cut the nut off with a dremel.
    Hit it with some PB Blaster or equivalent and let it sit for an hour. If that doesn't do it hit nut with some heat.
    or just cut the nut :)
    A good impact gun will usually do the trick also.
    +1. This is how I have always gotten the stubborn ones off.
  1. EFI Fox body strut tower brace
    By Dan B. in forum Ford Vehicles
    Last Post: 11-11-2014, 11:06 PM
  2. 2 Strut Tower Bars for Fox Body
    By b_turbo454 in forum Ford Vehicles
    Last Post: 03-19-2013, 11:08 AM
  3. Replies: 2
    Last Post: 10-03-2011, 05:59 AM
  4. 5.0 Strut Tower Brace?
    By 65 Fastback in forum Fox-SN95
    Last Post: 01-24-2009, 12:23 PM
  5. fox strut tower brace-4 point brace
    By PSPstang in forum Ford Vehicles
    Last Post: 05-12-2008, 07:12 PM
