Results 1 to 3 of 3
Thread: Built 96 Cobra For Sale
    Huntingdon PA
    1,136
    This is being posted for a very close friend of mine who isn't a member on here. This is his link on the corral where you can contact him via PM if you prefer, otherwise his number is below. I put a lot of time into this car last summer, i hate to see him sell it after all the time and money he invested without getting to enjoy any of it due to his hectic schedule. here it is.
    http://forums.corral.net/forums/must...l#post10598500
    General: 1996 Cobra laser red, tan interior
    most parts have less than 30 miles on them. Had car tuned at SGS automotive at end of last summer, decided to switch up blowers and now just dont have the time to invest into it anymore.
    currently car needs header gasket replaced and blower bolted up, other than that its ready to tune. paint is faded some with a spot missing on drivers front bumper.
    I'm sure many parts are missing from the parts listed below, but its what I could recall while making the ad. I have over 30k invested into parts and labor at this point, and have most of the receipts on file. No expense was spared on parts, with the vast majority being new. Will post pics tommorow afternoon (7/21)
    Car dyno'd 661hp/586 tq at end of last summer on the f1a @28 psi with conservative tune by sgs
    Willing to adjust price on car if someone is interested in it without the blower for a turbo build or something of that nature.
    15,000 obo. I can be contacted at 814.599.6387. Or here on SCM (but I dont always login daily)
    Engine:
    Stock bore 281 teksid block
    Diamond pistons 9.1:1
    Manley H-beam rods with arp2000 hardware
    ARP head studs, main kit
    New timing chains, etc
    cobra crank
    Billet oil pump gears
    MMR 7qt pan
    99/01 cobra intake with ceramic coated upper, port matched to accufab tb
    Single Blade accufab TB
    'C' heads stage 3 ported by fox lake
    comp springs, retainers
    MMR Stainless steel swirl polished valves oversized.
    5-angle valve job by MMR, new seats and valve guides installed.
    Ford GT cams
    3 core radiator
    Transmission:
    Upgraded Tremec 3550 26 spline input, 31 spline output
    Proshifted 2nd gear
    bronze fork pads
    pro5.0 shifter
    Lakewood blow proof bellhousing
    Zoom twin disc clutch
    adj quadrent,etc
    Alum ford racing driveshaft with lakewood loop
    Rear end:
    Eaton 31 spline posi
    moser axels
    MAC diff cover
    Ford racing 3.55 gears
    ARP extended rear wheel studs
    Power adder:
    Brand New satin vortech ysi ( mocked up, never ran )
    CX racing FMIC
    Custom routed 3" alum piping (clean setup)
    8 rib pulley kit
    Innovaters west 10% overdrive crank pulley
    Current blower pulley should end up around 21-25 psi ( as per kurgan)
    Vortech bv52 blow off valve (larger than mondo)
    power pipe by Sgs automotive with K&N filter (very clean install)
    Braided stainless feed/return lines for blower
    Snow methanol kit with braided stainless lines, plumbed into upper intake manifold with 2 nozzles and check valve
    progressive controller
    AIS meth tank located in trunk
    Suspension:
    AGX adjustable rear shocks
    Maximum Motorsports full length subframe connectors
    Fuel System:
    -10an feed
    -6an return
    granatelli motorsports pickup
    twin walboro 255 inlines with 'Y' blocks
    aeromotive FPR
    UPR 9/16" ID rails
    83 siemens deka lb low imp flow matched injectors
    AEM low impedence injector driver
    Guages/Electronics:
    PMAS HPX meter
    diablosport MAFIA
    Kenne bell boost-a-spark
    SCT quad chip
    speedo recal
    Autometer phantom wideband, boost, oil press, water temp, fuel pressure
    Shift light located in center vent
    Other:
    Taylor Battery relocation kit
    Summit battery disconnect switch above license plate
    Ford racing plug wires.
    Everything in intake tract has its own bung (iat,maf,etc)
    Majority of sensors are new, iat, iac, 02 sensors, etc.
    most parts have less than 30 miles on them. tuned car at end of last summer with an f1a, went to ysi never completed.
    have dyno sheet
    Exhaust:
    JBA shorty headers w/ stage 8 locking header bolts
    UPR offroad x pipe 2.5"
    MAC 3" catback system
    Wheels:
    03 anniversary wheels 17x9
    MT drag radials in rear
    709RWHP/750RWTQ
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    Sounds nice! Got any pics?
    Huntingdon PA
    1,136
    I will post some tomorrow.
    709RWHP/750RWTQ
  1. Replies: 6
    Last Post: 08-22-2013, 08:03 AM
  2. '91 built notch for sale in Uniontown
    By Troll in forum The Bar
    Last Post: 07-21-2011, 12:34 AM
  3. FS: Built 351 Windsor, Built Tranny
    By SlowSix in forum Ford Vehicles
    Last Post: 03-05-2011, 03:21 PM
  4. Considering sale of built AOD
    By HOTMARK7 in forum Ford Vehicles
    Last Post: 11-04-2010, 05:09 PM
  5. For Sale: Built 4.6L
    By stick947 in forum Ford Vehicles
    Last Post: 02-19-2010, 09:39 AM
Tags for this Thread
