Results 1 to 5 of 5
Thread: eliminating o2's
    cruisin for a bruisin geps91stang's Avatar
    Aug 2010
    connellsville
    160
    eliminating o2's
    ok so i just recently dropped my engine in my 91 gt i installed mac long tubes prochamber h and mac dumps now my question is is there anyway to completely eliminate the o2's from the car the reason i ask is it's so tight because of the aod trans i cant even get o2's in theres about an inch between the bung and trans i looked on a couple different site and couldn't find anything for my car or should i just unplug the o2's from the harness and plug the bungs
    Senior Member RogerStout's Avatar
    Jan 2011
    Lumberport WV
    281
    You need o2's. After the car warms up it goes into closed loop.. Its uses the o2's to adjust your AFR..
    wvstreets.CO
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Have new bungs welded in downstream in the exhaust a few inches. Thats what I did when I had an AODE with my long tubes.
    The best former Rodeheaver's Hot Rod employee ever.
    15gt
    Premium - Performance Pack - Recaros
    94gt
    410w - faceplated t56 - s478 - Gone
    Brookline
    2,897
    Quote Originally Posted by cwh19 View Post
    This... just relocate the bungs.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Back in the day ('07), I was too cheap to get a real tune done on my '90 supercharged notch, so I did it the ghetto way. Unplugged 02's, locked out distributor at 18* (race gas), and adjusted A/F's by fuel pressure. Worked awesome for my car, not sure how I cane about doing it that way, but the car ran great. I tuned the car with a wideband to 11.7 to 1 at full throttle, and it idled at 14.5ish. I had a really good PMAS meter though, the car wouldn't run with a 76mm C+L. FWIW, the initial combo was a stock short with GT40ps, N41, and Typhoon intake, 44lb injectors. Required around 58 psi fuel pressure. I blew that up (overrev), went to a stock long block, reduced down to 44 psi to maintain the same AF's.
    2014 M235i (wife's)
    1964 Ford F-100
  1. Replies: 31
    Last Post: 04-07-2008, 12:15 AM
  2. Eliminating Alternator.. what to do with wires
    By Pure Stock in forum Fox-SN95
    Last Post: 10-29-2006, 01:08 AM
