Results 1 to 2 of 2
Thread: Changing tune at track
    Was wondering does the computer take a few passes to adjust itself fully to a change in the tune if made at track?
    Asking as I made a pass yesterday and it was slower than expected. Looked at datalog and added fuel from 4-7k. Car responded by picking up nearly a tenth. Added a little more fuel to 4-7k and it picked up a lttle more and I left it alone for rest of day. Problem it seemed is it kept picking up each pass to point I gained solid .15 Ended up running pretty damn quick for a hot humid day.
    I had added new front O2 sensors with new set of NTK's as my less than year old Bosch's crapped out and were stuck lean.
    Did you see gains in trap speed as well?
    At WOT the car disregards O2 sensor input and uses the MAF only for fueling- no fuel trims are used at all.
    So, while part throttle driving can be dramatically effected after re-flashing your ECM during the fuel trim "learning period", WOT isn't going to be effected.
    So...no. If you were picking up ET (or more importantly in this case, trap speed) it's because the changes you made were benificial- after that, it's likely just coincidental.
    2005 Mustang GT
    11.2 @ 123
  1. Changing setups
    By Silverhatch in forum Pictures & Videos
    Last Post: 08-14-2013, 08:25 PM
  2. Changing the name of the site?
    By Sonic03snake in forum The Bar
    Last Post: 01-05-2009, 01:19 AM
  3. changing my clutch
    By jaa55 in forum General Tech
    Last Post: 10-25-2008, 05:14 PM
  4. changing injectors?
    By Johnny B in forum General Tech
    Last Post: 11-05-2007, 07:12 PM
  5. changing out cd player
    Last Post: 08-26-2007, 03:44 PM
