Results 1 to 20 of 20
Thread: Plugs 5 and 8 wet
    Senior Member RogerStout's Avatar
    Jan 2011
    Lumberport WV
    281
    Plugs 5 and 8 wet
    Lower intake gasket right? Any chance I can just re torque the lower intake and dry it up? Its not major they were only slightly damp. 1 and 4 looked good.I changed the lower about 3 months ago..
    wvstreets.CO
    Wet with what? Gas, condensation?
    Somerset Co.
    2,907
    ^^this... I read it last night and wasn't sure wtf you were talking about
    Jan 2011
    Lumberport WV
    281
    Wet I just assumed it was Coolant.. It did not smell like gas. When I pulled 8 and it was wet I tried to light it to see if it would burn off and it didn't.. Not oil could be condensation. Just seem logical because coolant runs across the front and back of the lower intake.
    wvstreets.CO
    REinstall and run it again and wipe off with a clean paper towel....green - coolant
    Jan 2011
    Lumberport WV
    281
    Will do
    wvstreets.CO
    Jan 2011
    Lumberport WV
    281
    The whole reason I pulled them out was a top end miss so I decided to regap the plugs..
    Here is one of the plugs this was 6, it was not wet but the wet ones look that same..
    Spark plugs fouled by MMT? From what I am reading that looks to be the case. Dont know if switching places where I get gas will help or not..
    wvstreets.CO
    stock heat range plugs?
    what's teh a/f ratio under part/full throttle?
    Jan 2011
    Lumberport WV
    281
    No wide band.. OBD1 so I know lean or rich if it throws a code thats it.. they are NGK Iridium TR55IX
    wvstreets.CO
    Somerset Co.
    2,907
    Ricer plugs...
    Street car!
    Jan 2011
    Starting a fire in your girlfriends panties!
    153
    Put some motorcraft or autolite plugs in that thing! No platinum or iridium plugs.
    427w, afr225, ci hyd roller, super vic, single stage, and swapped aode to tko600 to PA c4 w/brake.
    605rwhp 700rwtq
    MMFF june 09 feature car http://www.musclemustangfastfords.co...ker/index.html
    Somerset Co.
    2,907
    Quote Originally Posted by Naste95 View Post
    Jan 2011
    Lumberport WV
    281
    Some habits are hard to break.. LOL
    wvstreets.CO
    Jan 2011
    Lumberport WV
    281
    Pulled the plugs tonight and replaced them with autolite 764's gaped .044..
    5 and 8 were dry this time so WTF that was who knows..
    4500 rpm miss still there.. I guess I am swapping a fuel pump.
    wvstreets.CO
    Quote Originally Posted by RogerStout View Post
    Have you run any octane booster or Torco? Either will color a plug exactly like that.
    Jan 2011
    Lumberport WV
    281
    ^ got that one.. Yeah when I was running 19lb injectors adding a bottle of 108 made it run better..
    wvstreets.CO
    Do some diagnostics before throwing parts at it.
    Why do you think you need a fuel pump? Is fuel pressure dropping under load at high rpms causing a lean condition?
    Jan 2011
    Lumberport WV
    281
    My FP gauge in under the hood so I cant tell.. I am open to suggestions. You got an idea let me know.. The ECC is not saying I am lean.
    wvstreets.CO
    Buy a hose and run the gauge up to a point where you can see it while driving around.
    Jan 2011
    Lumberport WV
    281
    Will do..
    wvstreets.CO
  1. Zex wet kit
    By Martin0660 in forum Ford Parts
    Last Post: 07-04-2012, 01:52 PM
  2. NOS Wet Shot
    By Flyin Monkey in forum S197
    Last Post: 11-07-2008, 11:35 PM
  3. Compucar wet kit
    By red92notch in forum Ford Vehicles
    Last Post: 07-19-2008, 02:00 AM
  4. Zex wet kit
    Last Post: 12-15-2007, 06:04 PM
  5. Zex wet kit
    Last Post: 06-27-2007, 12:21 AM
