Results 1 to 18 of 18
Thread: Comp Thumpr cam experiances?
    Bunker Hill, Wv.
    672
    Picking up a 94/95 gt or cobra soon and considering a mild build over the winter. Anyone have any experiance with the Comp Thumpr Cams? I know the 94/95 ecu's can be fickle at times so that may be an issue. But it would be something along the lines of gt40 heads,shorties,mild intake ie gt40,cobra,comp poly intake,cam,tb and exhaust work. Just wondering,
    Thanks guys, Vince
    2010 Gt 5spd....WIFE's car.
    Mar 2009
    796
    There's a few variants of the Thumpr series cam.
    I know they dyno out just a hair under a good street cam.
    I don't know how they affect the ECU, but I'm sure comp can tell you.
    They have an excellent support staff, give em a call!
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Those cams are engineered for sound. Buy something else.
    2014 M235i (wife's)
    1964 Ford F-100
    Bunker Hill, Wv.
    672
    Mark thats what im starting to notice....think ill go another route. While the sound is cool im not adding parts just for noise i want the added power as well.
    Mar 2009
    796
    They're basically a good street cam with late timed exhaust valve.
    The lopey sound effect is caused by an exhaust pulse wave.
    They retain good bottom/mid torque, where a long duration cam is more peaky.
    Mar 2009
    796
    The Thumpr will perform about the same as the Magnum 270HR but with a nasty lope at idle.
    Bunker Hill, Wv.
    672
    I was hoping someone would have done some dyno testing lol. With that longer exhaust duration i bet i would make a horrible nitrous cam..hmmmm
    Mar 2009
    796
    Quote Originally Posted by FineLineMtrSprt View Post
    Actually, I was basing my comments on dyno testing by Big Joe Sherman
    If you want, you can search for the forum post at FordMuscle.com
    I am running one of these cams in an old school 312 Ford Yblock I am building for my 1960 Ford 300. It is made for sound. Looks like the power of a good street Comp cam but sounds like a monster! If you are going for power or something particular, look for a different cam.
    I wouldnt run this in anything that I have a goal of building more power with.
    Last edited by coralcoupe1993; 08-06-2011 at 06:52 PM. Reason: I cant spell worth SHIT
    Bunker Hill, Wv.
    672
    Ok cool ill research him and yeah if its just a noisy cam i might as well get a metal gear drive lol....which i would NEVER do. But im still researching it. One guy on corral.net said comp told him efi computers cant handle thumpr cams because the computer cant handle the big exhaust lobes..not sure how much truth is behind that but im looking into the specs/power output still. Im not going for a huge power maker, hell the most this engine will have for air flow will be ported gt40's.
    Trafford, Pa
    2,308
    I think any cam you install (properly selected to make power) is going to satisfy you sound wise. Even the little N41 I had in my old notch sounded "lopey".
    2014 M235i (wife's)
    1964 Ford F-100
    Bunker Hill, Wv.
    672
    any vids of that n41?
    Bunker Hill, Wv.
    672
    Actually just looked into that cam and its got a operating range of 2600-6200rpm...might be a lil much for stock gt40 heads and intake.
    never stock biminiLX's Avatar
    Beaver
    2,406
    Check out the new Popular Hot Rodding mag, they had a 347 3-cam dyno session and the Thumper performed the best. Not exactly a same comparison but first Thumper dyno I've seen.
    Trafford, Pa
    2,308
    That's what I ran it with, it was an awesome combo. 12.50s at 109, road race suspension on street tires, untuned (no chip, obviously optimised timing and FP).
    2014 M235i (wife's)
    1964 Ford F-100
    when you are ready i have a nice comp cam that your computer will like and should work with those heads if you have good valve spings in them , i'll give you the grind number
    No Secleter??
    Mar 2009
    796
    I told you Joe Sherman said the thumpr was an impressive street cam
    that compared well to other street cams on his dyno.
    Now you have another source to back it up.
  1. comp cam rockers
    Last Post: 11-16-2013, 06:04 PM
  2. WTB:cam for 5.0;TFS 1,AFM,comp
    Last Post: 07-18-2009, 10:37 AM
  3. Comp Cams XE268H-14 Cam Set
    By Mitternacht in forum Ford Vehicles
    Last Post: 03-29-2009, 03:19 PM
  4. Comp Cam and headers
    By 04yellowcobra in forum Ford Vehicles
    Last Post: 02-19-2007, 04:14 PM
