anyone know what sizes they are? are they standard or? i didnt have anything grinded just had crank polished and putting in new rod and main's
i looked for a bearing size but couldnt find anything.
thanks for any help
thanks for any help
What motor? if you do not get the crank cut, you will use the standard size.
thanks man, no the crank wasnt cut at all.
but its a 4.6 2 valve.
What exacty do you want to know.
if you didnt get anything cut then you just need std size
2013 Mustang GT
1999 Contour SVT
thanks, thats what i wanted to know 5.0
