Results 1 to 9 of 9
Thread: Running way lean
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Running way lean
    Did some tooling around in the ranger last night. At idle the wideband reads 13.5-ish which I think is good. Rolling down the road at a cruise (35-60mph) it is way lean (17-18). But at the point where I start to tip in the secondaries the AFR comes back to around 13.
    The carb is a Holley 750 that came off a well built 302 from Mark Aubele on the board. I've got it on a healthy 351W. My fuel pressure is 6# from a Holley Blue through a Holley regulator.
    So I'm thinking the idle circuit is fine, the primary jets need jumped up a couple sizes. When fully into the four barrel it stays around 14. That could even be fattened up a little to get closer to 13. So a jet change there also?
    This wideband is awesome but I can see how it would drive you nuts!!
    Your thoughts??
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Mar 2011
    Ashtabula Ohio
    34
    should be 14.7 at idle and cruise at wot it should be 12.5 for NA 11.5 for boosted.
    What is the primary and secondary jetting set at now?
    Armagh, PA
    4,331
    Not sure. Out of town for a few days. Won't get back into the garage until next weekend.
    Ahh fuque
    Member torqueboxer's Avatar
    white oak, pa
    638
    That carb is fine, dont do anything to it but maybe a primary jet change of one or two.
    Armagh, PA
    4,331
    Thanks for the input.
    Ahh fuque
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Dan,
    I had (well, Torqueboxer and I) set that carb up for an NA 302, making 347 at the wheels. I imagine you will need to step up the jet sizes at least a couple sizes. For the life of me I can't remember what we had in it, I know it wasn't set up square. I would try to get 14.5-16 at idle and 12.5-13.3 wide open. We made peak hp at 13.3, but backed it down to 12.7, lost 5 hp but I wanted it a bit rich so it would have a chance to hold together. Feel free to give me a call if you still have my number, if not PM me. I wouldn't go pounding on that truck WOT with it that lean.
    2014 M235i (wife's)
    1964 Ford F-100
    Armagh, PA
    4,331
    I was just rolling around to visit family. Didn't go but maybe ten miles and not once over about 4K. I've got too much time into this thing to go melting it down.
    I'll pick up a jet kit next week and start experimenting.
    Ahh fuque
    Get the primary's set up first and then start working on teh secondary's IMO. I would also lean out the idle a bit.
  1. Running Lean...MAF need upgraded?
    By Zoom50 in forum Fox-SN95
    Last Post: 06-20-2014, 10:17 PM
  2. Sitting with a lean
    Last Post: 08-18-2011, 06:11 PM
  3. running lean
    By 95V6 in forum SN95-New Edge
    Last Post: 12-12-2010, 01:18 PM
  4. Replies: 1
    Last Post: 11-18-2010, 01:11 AM
  5. running lean???
    Last Post: 08-26-2008, 05:47 AM
