I am doing the SN95 Cobra brakes and I have a feeling I may need the master cylinder / booster fron a 94-95 Stang. Maybe a 96-98 will work also. Testing the waters to see what is out there.
hydroboost? i have an old one sittin around.. didn't think they used vacuum in sn95![]()
If you go to the Zone and order a 93 cobra booster what you will get is a 94-95
booster that has the mounting studs changed to fit a fox body.
And there not that much.
But these are for the GT brakes not for Cobra ,, Not sure if that will work OK or not
I installed the Cobra brakes on my 95 and retained the stock GT booster and master cylinder. The only noticeable difference was a slightly firmer pedal feel afterwards, but the brakes work great. The booster above looks to be the ticket for a fox install.
I have one. Been sitting on shelf for a while.
I think the biggest booster out there is the 99-04 V6 I used it when i was doing my brake swap. I only minimal reaming to get to fit the fox firewall......i changed it out for a hydroboost later in the cars life.....
I might still have the whole setup, ill have to find out if i still have it
03 Torch Red Anni. Ed. Cobra
01 cobra: traded
93 LX Modular 4v swap
