Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 59
Thread: Tell me truth about aftermarket heads
  1. #21
    never stock biminiLX's Avatar
    Beaver
    2,406
    Honestly anything that will be stock shortblock is best with a TFS Twisted wedge head. I say that because its the only head that will clear stock pistons with 2.02 valves and even a small cam and can be ported to support 8-sec power down the road if needed.
    I personally wouldnt waste time swapping on a GT40 head.
  2. #22
    Quote Originally Posted by PaceFever79 View Post
    It's the peak horsepower that will distort or split the block.
    The main webbing and cam galley can't handle 500+ HP for very long.
    I'd guess 12 psi @ 6000 RPM is probably in the 450 range.
    I have 3 years on my 576rwhp stock shortblock car. I drive it daily.
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
  3. #23
    Mar 2009
    796
    Yeah? How often do you lay into the full 600+ HP?
  4. #24
    Mar 2009
    796
    I think some of you got compensation issues.
  5. #25
    I just think it's hit or miss with different cars. There really is no magic number of where you'll grenade these things. Some can't handle 450hp, and some are like the above mentioned car. Arguing over it is pretty much pointless.
  6. #26
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    He does very often, trust me.
    2014 M235i (wife's)
    1964 Ford F-100
  7. #27
    Mar 2009
    796
    I agree with your entire statement.
    But good engine designers don't build on hit or miss.
    And they especially don't build on urban myths!
    If you're feeling lucky, go right ahead!
    Just be prepared to Fail...
  8. #28
    Trafford, Pa
    2,308
    Another data point is a buddy of mine's '88 Notch, AFR's, small cam, Systemax intake, S-Trim, spinning the tires above 5300 made 430+ on **********'s dyno (I suspect it makes much more without the tire spin), has been put through torture like this all year..
    [ame="http://www.youtube.com/watch?v=r0Ob1RZlNDU"]Dan Reed 2011 Giants Despair Hillclimb SM Record 45.3 - YouTube[/ame]
    And this is the shortest hill we run. At Duryea this past weekend this car was basically WOT for the entire 2.2 miles. Holding together, stock block, safe tune, good fuel.
    2014 M235i (wife's)
    1964 Ford F-100
  9. #29
    Mar 2009
    796
    Cool... vid.... (and Duryea is the bomb!) ;)
    WOT isn't the issue.
    A run like that (or a dyno pull) is at max RPM/HP for a brief time.
    Nothing like a long charge, say the big end of a 1/4 mile.
    Generally, you get away with RPM, HP, or detonation.
    But any combination of the three is a problem.
    Yeah, you can tiptoe 500 HP and beyond with a stock block 5.0
    I just don't tell friends, you-can-do-it, no problem!
  10. #30
    Trafford, Pa
    2,308
    Huh? Did you watch the video? Giants' last straight is a 1/4 mile, 22* incline, at WOT. The beginning is basiclly a 1/4 drag, up hill. He is going into T1 at 120 mph. How is this easier on an engine than a single 1/4 mile run?
    Duryea has a .8 mile finish, uphill, at WOT. This is after over a mile of constant WOT, to lift throttle, downshifting, banging the limiter, etc.
    You've run these hills, haven't you?
    2014 M235i (wife's)
    1964 Ford F-100
  11. #31
    Mar 2009
    796
    I have raced Giants and Duryea many times.
    WOT against up a hill around turns is not sustained WOT at maximum RPM+HP.
    Honestly I don't care to argue what you can do to a 5.0 before it blows.
    Shall we talk about how they often crash when they blow?
    Anyway, it's your car, do with it as you like!
  12. #32
    Mar 2009
    796
    Naturally aspirated HP is my thing.....
    [ame="http://www.youtube.com/watch?v=qHoNC4RdU18"]Merlin Miller getting it done in a Sunbeam Tiger[/ame]
  13. #33
    Trafford, Pa
    2,308
    OK, so TWO Wide-open throttle 1/4 mile straightaways, uphill, with 1/2 mile of turning in between them, on/off throttle, is easier on an engine than, ONE 1/4 mile straightaway. Gotcha.
    2014 M235i (wife's)
    1964 Ford F-100
  14. #34
    Mar 2009
    796
    Hey, if you're trying to impress me, it ain't workin!
  15. #35
    Mar 2009
    796
    Anyone can build a hand grenade boost motor.
    Sometimes, they even stay together!
  16. #36
    Trafford, Pa
    2,308
    Impress you? What are you talking about? You are saying that one flat 1/4 mile is harder on an engine than two that are uphill. You are making no sense.
    2014 M235i (wife's)
    1964 Ford F-100
  17. #37
    Mar 2009
    796
    It's because you're not smart enough to understand me.
  18. #38
    Trafford, Pa
    2,308
    Smart enough to understand what? There is nothing to understand, you haven't made an intelligent argument in the entire thread.
    You accuse me of trying to impress you so you go out and find a video of Merlin Miller, from the hillclimb I competed in over the weekend mind you, like that shows something.
    Who are you trying to impress? How about you post the times you have run there, and then I will. Will mean a whole lot more than you name dropping a full tilt GT-2 car owner. Of course it is fast, it weighs 2500lbs and has 600hp. Big surprise. He got FTD this past weekend too.
    Dude if you have a problem send the god damn parts back. Already told you I would send you your check, I have it in my hand ready to drop in an envelope. You paid 100 bucks (and I paid 13 dollars shipping, so $87) for camber plates and a bumpsteer kit. I practically gave you the parts. Seriously, I will eat the shipping, send them back to me.
    2014 M235i (wife's)
    1964 Ford F-100
  19. #39
    Mar 2009
    796
    You boost guys are so grandiose you miss half the sport!
    All you do is point and shoot! Point and shoot! All it takes is big balls.
    Tweaking a few HP from a high strung NA motor, or a few tenths off your time,
    takes real thought, real engineering, and real driving skills.
    But you're not so worried about that!
  20. #40
    Trafford, Pa
    2,308
    Here you go, Duryea Hillclimb times
    2008: 1995 BMW M3 (NA, near stock)
    124.9 first time ever at the hill
    2009: 1995 Ford Mustang (NA 302, carbed, home built)
    118.6 broke after a few runs
    2011: 2009 Chevy Cobalt (2.0 Turbo, stock with tune and tires)
    122.1 DSP record broken by 12 seconds
    Wait, didn't you run in DSP? What was that thing about driving skill again?
    2014 M235i (wife's)
    1964 Ford F-100
  1. Truth or Dare - flywheel balanced to the pulley??? BS???
    By Warrior1670 in forum General Tech
    Last Post: 05-19-2011, 07:01 PM
  2. WTB:aftermarket SBF cylinder heads
    By 1badnotch in forum Ford Parts
    Last Post: 04-17-2010, 04:06 PM
  3. Aint that the truth!
    By Shadowstealth in forum The Bar
    Last Post: 05-16-2009, 03:41 PM
  4. Some truth
    By John4cam in forum Pictures & Videos
    Last Post: 02-23-2009, 05:24 PM
  5. Truth Spoken - read this before you vote
    By PaxtonShelby in forum The Bar
    Last Post: 11-04-2008, 06:53 PM
