does anyone know how to convert rhp to flywheel hp thanks
just a quick internet search brought up this:
http://www.mk5cortinaestate.co.uk/calculator4.php
There's also various forum threads with people asking the same question. A lot of variables come into play though when trying to figure that out so you can never get a 100% correct answer.
2013 Mustang GT
1999 Contour SVT
If its a manual your looking at about 15% and an auto is about 17%-20%
There is no accurate way to do this, too many variables. It is also pointless, except for bragging on the net, take it to the track.
2014 M235i (wife's)
1964 Ford F-100
The type of dyno, and what they have messed with (corrections) also come into play here ... A dyno is a tool, strap it down and make a pull, make changes and strap it down to the same one again and pull ... if the second run makes more power the change worked ;)
when you going to update that signature????
Current Stable
1993 Red Cobra
Previous Stable
2012 White Mustang-Traded
2003 Black Cobra-Traded
1998 Black Cobra-Traded
1991 White 5.0 Conv-Sold
You should take it to the track. It will run 10's. I've seen it do it:)
17 Ram 1500 Big Horn Hemi
16 Comp O GT Performance Pack
I know as does Mark and everyone else that knows the car and you, that it went to a good home. But you still need to run the heck out of it.![]()
I don't believe the 'ole 15% for manuals and 20% for autos BS. We are all so used to dealing with cars that make 300hp flywheel and 240-250 rearwheel hp, that that 15/20% nonsense just happened to work out. I have nothing to support this, but I believe most cars lose about 40-50hp through the drivetrain. That's also why everybody goes on and on and on about the new 5.0 being underrated at 412 flywheel when they're putting down 370 to the wheels. No, it's not underrated, it just lost 42hp through the drivetrain. the old 15% calculation would put you at 350 rwhp. When the hp goes up, and in some cases goes up considerably, do you guys still believe you lose 15%??? does a 1,000hp engine generate only 850hp on the dyno? does it really lose 150hp through the drivetrain?![]()
ok I changed the pics but I am having one hell of a time changing the avitar Uisng photobucket can someone give me some sort of direction to do this I tried jsut about every combo there and cannot get it to take thanks
A straight percentage is not necessarily true and the actual components of the drivetrain determine how much loss (ex--auto vs. manual and TKO/9" vs. T5/8.8") however, the percentages of loss DO increase with higher power due to heat and friction, so its not just based on the drivetrain behind the engine.
The 15% & 20% methodology is just a generalization. Not intended to be exact - just ballpark.
