Results 1 to 9 of 9
Thread: standard bore size of a 98 4.6
    May 2011
    washington pa
    82
    does anyone know what it is? reason im asking is im buying new pistons and i noticed theres a bunch of different sizes
    3.551, 3.552 3.556, 3.558 in etc etc.
    really appreciate it. thanks
    3.552 is standard for all 4.6 and 5.4
    May 2011
    washington pa
    82
    thanks really appreciate it
    May 2011
    washington pa
    82
    im looking at hypereutectic piston on summit racing and dont want to spend a bunch of money on forged pistons.
    I know you said the standard bored is 3.552 but these pistons are only offered in a 3.551 whats the deal?
    they only have the expensive shit in
    this is what i was looking at
    http://www.summitracing.com/parts/SLP-H591CP/
    can they still be used or?
    Yes you can use them. .001" will give you a nice slip fit like the piston should be. The rings make up for the difference in size.
    May 2011
    washington pa
    82
    awesome thanks alot!
    another question, sorry this is the first motor i ever did.
    I bought piston rings, standard size cause i was going to re-use the old pistons before i noticed the teflon surface was worn out.
    the oil rings and center rings fit on all pistons but the top compression ring was to thick to fit in the rail???
    i checked over and over and these are the right rings. 1.5 1.5 and 3mm
    i thought there might of been a difference between mustang and lincoln 4.6's but i get the same part number every website i look on.
    1.5mm top and 2nd ring with 3mm Oil ring is the normal size. Sounds like the ring set you have is wrong. What are you doing with motor. Just a general rebuild?
    Jason feel free to give us a call at the shop monday and I can help guide you thru this with some advise.
    May 2011
    washington pa
    82
    thats what i thought for sure i got the wrong rings. I put the rings side the by side and the middle and upper ring are the same thickness.
    Im wondering if ford used different pistons because first of all im using a 4.6 from a lincoln towncar.
    granted its still the 4.6 i ordered rings for the lincoln NOT the mustang.
    The top ring fits in the piston groove of the mustang, but not the lincoln.
    I got new pistons on the way anyways so maybe that will clear this up
  1. Standard to Auto
    By J-rod in forum SN95-New Edge
    Last Post: 09-09-2013, 07:25 AM
  2. This should be the standard crown vic!
    By John4cam in forum Pictures & Videos
    Last Post: 01-18-2011, 12:42 PM
  3. Tire Size Comparison. Can you guess the size?
    By joed in forum Pictures & Videos
    Last Post: 07-20-2010, 10:12 PM
  4. wtb stock 302 standard bore 302 pistons
    By badstanglx in forum Ford Parts
    Last Post: 09-13-2009, 05:29 PM
  5. This is why standard ARPs suck:
    By Bluemeanietsi in forum Pictures & Videos
    Last Post: 07-30-2007, 11:34 PM
