Results 1 to 4 of 4
Thread: TFS Track Heat for sale
    Senior Member TJH64's Avatar
    Delmont PA
    320
    I am considering selling my TFS Track Heat intake, which would include the upper and lower, plus a 1" phenolic spacer for $300. This would make a nice upgrade for any 302 based engine. It is super clean and only has approx 2000 miles on it, and was bought brand new, not second hand.
    Below is a photo of it installed on my engine.
    What are you changing to, Holley Systemax??
    Delmont PA
    320
    I'm not sure, but if I stay EFI, that would probably be high on the list.
    i b where im at
    674
    Sent you a pm !
  1. TFS Street Heat / Track Heat 3/8" Spacer
    Last Post: 12-02-2013, 05:46 PM
  2. N.I.B. Trick Flow Track Heat Upper Plenum *ONLY*
    Last Post: 08-27-2013, 01:24 PM
  3. Trick Flow SBF track heat heads 205CnC - Damaged
    Last Post: 07-06-2010, 04:47 PM
  4. TFS Upgraded TRACK HEAT valve springs,retainers,locks
    Last Post: 05-20-2007, 07:13 PM
  5. 4.6 2V Trick Flow Track Heat lower intake???
    By Troll in forum SN95-New Edge
    Last Post: 04-29-2007, 01:12 PM
