i started my clutch replacement today, the stocker gave up 2 weeks ago :( i got car up in the air and pulled trans today , the car is getting a spec 3+ " thanks to bob " i hope to get clutch out and new one in tomorrow.
Put an auto in it. That's the way to go, yo.
here is one i'll take some of clutch today
here is another and joe its staying a stick
gotta stay with the 3rd pedal. car looks Goood
hmmm what's next?
Clearly ... easy to launch off idle that way too ...
No pictures, but here is Troy launching it off idle a few years ago ...
http://good-times.webshots.com/video...66453426QonYGU
Was the pressure plate broke?
just got in from garage, it had to be the pressure plate ,the disc looks fine...? the throw out bearing was running out of true too ?
is the stock clutch a luk? and you can hear that i was clearly above idle on that pass lol
Well, most everything is build on a Luk core or parts, so finding it on anything is likely. There are only like two companies that make the basic parts for clutches, everone assmebles as they see fit with those parts (and Luk) is by far the biggest) ... I see a lot of times, someone will but a performance clutch from someone then complain it's only a Luk rebranded ;)
The pressure plate I took out is alot shorter than the spec going in?
The spec is deffinately a higher stack ...
That all goes back to my problems with adjustment earlier this year when I changed ... None the less, I've run the spec with the stock bell set-up without issue.
found problem with clutch , it was the pressure plate the rivets pulled out of the straps
i think the heat from slipping burned them off lol
[QUOTE=Pure Stock;291129]Too much rpm in the launch.....[/QUOT
Girl technique on the pedal operation ...
Do you have it together yet? Man, this is turning into a long clutch swap![]()
it will be together this week i have been cleaning every thing under there while i have it apart
well an update , it has taken way to long, but the trans is back in and the car in on the ground and off the jack stands , all i have left to do is the shifter and console and take it for its break in drive lol
F I N A L L Y (Yeah it was that long) :D
Shouldnt need much break in ;)
Nice. Smooth install?
