Results 1 to 11 of 11
Thread: Fox width rear end with disc brakes and 5 lugs.
    Built, Cammed, CCW'd SVT NateSVT's Avatar
    Monroeville
    856
    Question Fox width rear end with disc brakes and 5 lugs.
    I want to start ordering parts asap for this rear end.
    I already have a Fox housing and 3.55 gears. I'll order the girdle when I buy the axles and I'll probably use a Ford 31 spline carrier.
    I want it to be Fox width.
    Don't need ABS.
    5 lug.
    Disc brakes.
    What brakes can I use? Can I use 94-04 GT brakes with some type of special brackets or something?
    Are these the axles I need?
    http://www.summitracing.com/parts/SUM-700127/
    The axles come with bearings and seals, what's a good kit that comes with all the other bearings and shit that I need for the rear end?
    2004 SVT Cobra - sold
    2000 Yamaha R1
    2006 Yamaha R1 - Raven
    10.89 @ 127.6 1.61 60' with a ported Eaton
    Senior Member celeste's Avatar
    Uniontown, PA
    276
    If you are using a fox housing and want to convert to rear disc, the easiest route that I found is Northracecars. Thier bracket works well and if you have questions when you call, you get to talk to the guy that owns the company and designed the bracket, not just a salesman. The only snag that I hit is it kicks out the wheel width a little because I used c clip eliminators. Here is their link and another link to a great site about rear disc conversion and 5 lug conversion for foxes.
    http://northracecars.com/Brakes.html
    and
    http://home.comcast.net/~mjbobbitt/mustang/page1.html
    http://www.fquick.com/celeste
    1989 Mustang GT 663 RWHP
    MM&FF May 2010 Cover/Feature Car AND 5.0 Magazine Oct. 2011 Feature Car
    1991 Strawberry Notch
    2003 Cobra White with Parchment inserts (1 of 170)
    1992 Calypso LX
    2008 Roush Blackjack #30 of 100
    MM&FF Article
    http://www.musclemustangfastfords.co..._gt/index.html
    5.0 Article
    http://www.mustang50magazine.com/fea...ble/index.html
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Celeste beat me to it. I also used NRC brackets and axles. Worked like a charm.
    2015 GTPP
    Brookline
    2,897
    Did I see somewhere you're building a Factory 5 car? Let me know if you have questions on stuff, we built one at the place I used to work.
    Monroeville
    856
    Thanks for the replies. So I think what I need is the bracket only kit in the SN-95 column, that way I can just use normal Mustang V6/GT brakes with Fox width axles. I'll order the brackets, axles, and girdle tomorrow. Anyone have a suggestion for what bearing kit I should buy?
    Does this have everything else I'll need?
    http://cgi.ebay.com/ebaymotors/Ford-...item5addcd0fca
    Quote Originally Posted by dannythekid View Post
    Yup, got the kit last week. I'll let you know if I have any questions, thanks!
    I have the front suspension and brakes done and I'd like to get the rear done soon so I can figure out what size and backspacing wheels to go with for the rear.
    2000 Yamaha R1
    Robinson Twp.
    2,143
    Quote Originally Posted by NateSVT View Post
    Very cool Nate! Keep us updated on the progress
    2015 Charger Hellcat
    85 GT
    73 F250
    Lifted, 35's, 460 4spd
    Real name = Ray
    Brookline
    2,897
    I believe that kit is what you are looking for and yes, it is the SN95 stuff to convert the rear to disc, same as a 5lug swap on a fox mustang and adding rear disc.
    Here's the one I was talking about:
    What driveline are you going with, or is that still classified?
    Monroeville
    856
    Thanks Ray, I'll probably start a thread with more pics once more parts get here and I start putting it together.
    Dan - That looks sick! Is that a Terminator motor?
    I'm gonna be using a Coyote motor, TKO600 with midshift, 4 into 4 headers, Boss intake manifold, SCT X-Cal 3, probably a tune from Jon Lund with the "ghost cams", return fuel system, 3.55 gears. Thinking about putting my CCW Classics on it.
    2000 Yamaha R1
    State College, PA
    3,552
    holy shit did you win the lottery or something? seriously...
    sweet kit car by the way. I'd like to do one someday
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    Brookline
    2,897
    Yeah its got the Terminator driveline in it, T56, custom driveshaft and a ford 8.8 SRA from Shaggy's old Mustang. I'll have to see if I can find the pics from my DSLR of it.
    A coyote motor will be awesome in there, I can't wait to see progress on it!
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    When we built a Daytona Coupe, I am pretty sure we used Mustang wheels on the car. Had 315s out back with 10.5 inch rim, and 275s up front on a 9. There was plenty of room. On my dad's Superformance (which should have similar room), we ran a 275 up front on a 10", and a 335 out back on an 11". They were pin drive wheels. There is a TON of room to fit tire on these cars.
    2014 M235i (wife's)
    1964 Ford F-100
  1. Fox Rear End, Axles, Brakes
    By NateSVT in forum Ford Vehicles
    Last Post: 07-06-2012, 05:48 PM
  2. 8.8 Turbocoupe rear with four lug disc brakes
    By Donstang86 in forum Ford Vehicles
    Last Post: 01-16-2012, 08:43 PM
  3. FS: 8.8 Solid Rear Axle. Cobra Brakes! Disc-to-disc.
    By 01CAMMER in forum Ford Vehicles
    Last Post: 12-11-2010, 11:10 AM
  4. Replies: 0
    Last Post: 09-16-2009, 01:35 AM
  5. what rear disc brakes?
    By yeahloh95 in forum General Tech
    Last Post: 07-31-2009, 01:50 PM
