Results 1 to 20 of 27
Thread: 5 lug conversion / brake question
    Junior Member Stangzrule's Avatar
    Connellsville, PA
    521
    I am getting ready to do a 5 lug swap. I am using SN95 spindles with dual piston PBR's up front and ranger axle and drums out back. I saw on another site that some people have had trouble with their pedal pressure and brakes not working right with this combo. Eventually I would like to get rear disc but right now the budget isn't there. Anybody have any experience using these discs/drums?
    out in the woods
    4,948
    to do it correct, you need the booster from the sn95 also.. the stock booster on a fox doesnt have enough pressure for the dual pistons. it will still stop you but it's the pedal is just a little softer then stock..
    2003 polaris predator 500
    (wanna ride,just pm me!!!)
    Yellow is faster!
    York PA
    273
    Quote Originally Posted by INSANELY CRAZY View Post
    Agreed!
    Or you could forgo the 13" rotors up front and run the GT brakes all around. Thats what I have on my fox and it stops in a real hurry!! I did my swap for 400 bucks. This includes the master cylinder, booster, and prop valve from a 95.
    Later
    I had no problems with mine. I esed the PBR calipers, drum rear and my master and booster. Pedal feels great and it stops real good. Total invested is about $50-100.
    Farmington WV
    4,672
    well im picking up a rear 5 lug disk conversion for $50
    now i need to find the front....i imagine going disk all the way around i definately need to get the 95 master cyl? what else?
    LowHill
    2,679
    Thats about what I have in mine, I used 94GT stuff and ranger axles, my booster. Pedal is a little soft, but it does stop nice. Don't forget you'll need a spacer for the balljoints or balljoints with more threads (like steeda x2's)
    out in the woods
    4,948
    Quote Originally Posted by lib88stang View Post
    and an alignment... tires will be tilted in at top
    Connellsville, PA
    521
    Thanks for the info guys. Anybody have any rear disc parts laying around?
    Connellsville, PA
    521
    I already have ranger axles/drums. If I decide to go with rear discs can I still use the ranger axles?
    Farmington WV
    4,672
    LowHill
    2,679
    Spindles,calipers,rotors,banjo washers for the brake lines,and either new balljoints like the x2's or a spacer/ stack washers.
    Farmington WV
    4,672
    what about master cyl/ booster? if doing disk on all fours?
    I used mag wheel washers. They are hard as a rock and act only as washers anyways. I used 3 on top of each side. The fox balljoints are just a tad too long and lack thread at the bottom for proper tightness. I aligned my car on my garage floor with a lever, brake line and a sharpie. I put the toe at 1/8 in. It equaled about 16 turnes on both sides. My camber is at about 1/8 bubble or about 2 degrees. I have no idea what factory specs are so I cant really get it right. No pulling and it handles great. Stock cc plates too.
    What are you getting it from?
    Farmington WV
    4,672
    94-98 mustang 8.8 rear
    out in the woods
    4,948
    i believe the axles from 94-98 are longer then stock axles in ur fox... thats why you run ranger axles cause they are the same length
    Connellsville, PA
    521
    Can you use ranger axles with rear discs?
    That rear is too wide. People use it but you are limited on your rim selection. Do research before you decide to use it. On the other hand, I can make anything. That is the option I was gonna use. Cut the brackets off the housing and weld them to mine. check the site www.sn95brakes.com very usefull and lots of info there.
    out in the woods
    4,948
    Quote Originally Posted by Stangzrule View Post
    Farmington WV
    4,672
    thought you were currently running a 7.5" from a 94-98
    and is .75" each side really that big of a difference?
    edit- i was going to use the axels...not the whole housing.
  1. Replies: 5
    Last Post: 03-21-2014, 12:25 PM
  2. Classic Mustang Disc Brake Conversion issues
    By Max Power in forum Classic
    Last Post: 07-08-2012, 09:38 AM
  3. Replies: 0
    Last Post: 03-13-2011, 08:01 PM
  4. 5 Lug Conversion Question
    By TheGreatWhite in forum Fox-SN95
    Last Post: 08-24-2010, 12:13 AM
  5. Cobra brake conversion
    By dpl133 in forum SN95-New Edge
    Last Post: 05-21-2010, 10:08 AM
