Results 1 to 15 of 15
Thread: Garage Door Spring Replacement....?
    Spencerport, NY
    3,762
    Well, my first repair of home ownership is upon me.... The garage door spring on one of my doors broke the other day - scared the living $hit outta me... sounded like someone drove into the side of my house.....
    Nonetheless, i was under the impression that these could only be installed by garage door professionals (and that it was going to cost me an arm and a leg), but after doing some looking on the internet, there appears to be a lot of DIY people that have done it.....
    Has anyone here done it??? The springs appear to be relatively cheap, in the $20-$30 range... so when you pay $500 for someone to come in and do it, you're really getting the shaft...
    I don't have a problem tackling it myself, but as always, if anyone has experience doing it and would like to help fix mine, i pay in food and drink.... :D
    2015 Corvette Z06
    - Shark Grey / Kalahari
    State College, PA
    3,552
    I didnt actually watch these vids, just skimmed through them, but they seem like pretty good instructions. Also, the comments are really positive so this may help you:
    [ame="http://www.youtube.com/watch?v=7DbiERklj8Y"]Garage Door Spring Repair and Replacement - HABPRO of Atlanta - Part 1 - YouTube[/ame]
    its 3 parts I believe
    2013 Mustang GT
    1999 Contour SVT
    Spencerport, NY
    3,762
    I left out an important peice of info.... mine are the type of springs that are above the door in the center, NOT the ones that run along the sides...
    2015 Corvette Z06
    Spencerport, NY
    3,762
    thanks, i'll have to watch it when i get home...
    2015 Corvette Z06
    You need the right size/tension spring for your door. If installed improperly your opener can be under too much load, causing it to fail prematurely. I called Hunt Door Company - they're in Moon - when mine went bad. My door is solid wood, about 1.5 inches thick - approx 16' x 7' - and it weighs a TON. I wasn't about to do it myself. I believe it cost me $200 total. He said my old spring was 2 sizes too light. It was always very hard to lift the door manually - like when the power went out. Now, it is MUCH easier with the correct size spring properly adjusted. If your doors are not heavy ( you have the 3 single doors, right? ) then maybe you can do it yourself. But for $200 ( and yours might be less ) I'd rather have a pro do it. Heck - he might even cut you a deal on the other 2 doors if you want to change them out at the same time.
    Gotta love home ownership!!
    Brookline
    2,897
    Honestly, I would have an insured garage door company do it. My mom just had to have someone come out to make adjustments on her garage door cus it came off the tracks, and it was only $120 for adjustments and to replace a wheel. Those things hold such high tension, it's not worth losing a finger.
    Although, they are a lot less dangerous than the older springs that go along the rails on each side. Ask me how I know about those...
    Bish, they are actually very easy to do. A good friend of mine installs them for a living. There is a certain spec that you have to follow for the number of windings you have to put on the spring. There are markings that will stagger as you wind the spring and they are what is used to gauge the tension. Important thing is to make sure you have good bars for leverage when winding the spring and make sure you wear gloves. If you slip when winding them, you will cause damage, most likely to yourself.
    Spencerport, NY
    3,762
    Thanks Ed...
    the only thing that's making me think about having someone else do it is this: a.) a place my coworker went to puts a lifetime guarantee on the whole job... if the spring ever breaks again (which we know it will) then they will replace it... so its a little bit of an investment, and b.) i think places usually come out within a day or two and do it.... I don't have a clue when i'll get a chance to do it.... I'd have to order the spring, wait for it to come in, create the bars needed, etc, etc... just seems like it might be 2-4 weeks til i'd get it done... and only a coupe days later, i'm already annoyed by having to open the door behidn the TA or Lexus to get out of the garage
    2015 Corvette Z06
    Polar Vortex
    6,031
    I agree with Ed, those things are freaking dangerous.
    Just remember, it should not be more than a $200 charge to have someone come out and do it.
    Brookline
    2,897
    I would think around $100 or less...
    Was $200 total for the big spring on my 16x7 door about 5 years ago.
    Senior Member SteelTownStang's Avatar
    Mar 2010
    Pittsburgh
    619
    Must be the weather or something... one of mine recently went, and I know of two others with the same problem. Weird! Easy change... the spring is color coded according to weight. Look at the end, and match the color for your replacement. Make sure that you reinstalled the "safety" cable. Good luck!
    CAR: 2012 GT500 Black w/Grabber Blue Stripes (Sold)
    RECENT CAR: 2008 GT500 Red w/White Stripes
    PREVIOUS CAR: 2007 GT Black/Black
    MODS: VMP 2.59 Pulley & Tune, JLT Induction Tube, Airaid Blue SynthaMax Filter, Painted STB Brace, FRPP Springs, BRM Adjustable Panhard Bar, Borla S-Type Exhaust, 20% Window Tint, Speed Dawg Shifter, NXT Hood Lifts, CDC Dead Pedal, Kicker Speaker/Sub Upgrade, Cobra Floor Mats, 2013 Splitter, SVTPP Wheels & Tires, Cervini Tinted Taillights, V-Led 5K Fog Lights, etc.
    I believe his spring is a torsion-style spring that mounts on the front wall of the garage - not along the top of the track where the door travels. A pipe runs through the torsion spring, which is loaded and locked to the pipe when the proper tension is set.
    ok i know your dying to answer, so,,,,how do you know???
    JUNK IT!
  1. Garage door help...
    By MinGry03 in forum The Bar
    Last Post: 01-16-2011, 11:14 PM
  2. Replies: 0
    Last Post: 01-14-2010, 07:56 PM
  3. Mustang replacement
    By cory04gt in forum Pictures & Videos
    Last Post: 02-19-2009, 11:41 AM
  4. WTB: Garage Door Mat - Any Suggestions
    By DRRummel in forum The Bar
    Last Post: 08-27-2008, 04:20 PM
  5. Here is my mustang replacement
    By 3ggt2 in forum Pictures & Videos
    Last Post: 07-26-2007, 04:49 PM
