Results 1 to 5 of 5
Thread: Drag wheel question
    fairmont,WV
    1,352
    Drag wheel question
    I've been looking to pick up a set of weld prostate......would my stock studs in the rear be good enough or do I need to upgrade to longer/stronger studs?
    XXX RWHP
    XXX RWTQ
    Weld Prostate??
    Is it adequate or is it legal are ethereal questions.
    Fundamentally, there is no issue booting them on a running them with the proper shank lug nuts.
    The issue is in the rule books. They say the stud must extend past the face of the wheel by at least the diameter of the stud. On a Ford, this is of course 1/2". The stock studs barely make it through the thick flannel of the Weld wheel, so long studs are required to meet the rule.
    As far as,a strength thing, a shank lug nut has,a ton of threads engaged inside the wheel, but in effect, the head that clamps the wheel does not have any threads in it with a stock stud. If the head broke off the nut, the wheel could come off. That's the drive for the rule. Now how many times do we see lug nut heads break off?
    Ultimately, its your call, and if you are going to run at a sanctioned track, there is a good chance it will be checked. PRP cracked down on this for a while, then let up, then I was told they was checking again this weekend.
    To be legal and safe, put the studs in. They can be a PITA with street wheels at times for sure.
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Quote Originally Posted by paxtonshelby View Post
    weld prostate??
    ouch!
    fairmont,WV
    1,352
    Weld Prostate??
    Sorry I was still asleep lol....Bob thanks for the advice.
    XXX RWHP
    XXX RWTQ
  1. Yet another tire/wheel fitment question.
    By phillysrt4 in forum S197
    Last Post: 06-18-2014, 06:20 PM
  2. Corvette Drag/Street wheel combo pack
    Last Post: 06-04-2013, 05:40 PM
  3. Rear Drag Wheel PKG
    By mr4teth in forum Ford Vehicles
    Last Post: 09-08-2009, 11:09 PM
  4. poll: wheel color question
    By 97LaserRed in forum The Bar
    Last Post: 06-12-2009, 01:47 PM
  5. wheel fitment question
    By blaze00 in forum General Tech
    Last Post: 06-10-2009, 11:19 PM
