Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: Transmission choices (long)
  1. #21
    i think a t-5 dog ringed for third ,would work great
  2. #22
    Oct 2011
    Colver, PA
    40
    i have a tko 600 in a 72 nova 427 sbc,i would not recomend it ,mine took 3rd gear main/cluster and1st/2nd syncro, cost over 700 in parts, plus it never shifted very good over 6000 rpms
  3. #23
    I bet that stroker sounds pretty darn mean over 6k...
  4. #24
    2,103
    I think my brother has a gforce t5 in the turbo v6, I'll have to ask him about it, or get him to respond to this.
    03 Cobra=slow show car...
    13 F-150 Limited
  5. #25
    Long as I stay with a manual trans Bob it will be faceplated 2-3-4. I saw a TKO500 for sale for a grand too comes with a 4.6 bell which is useless for you but still not bad price. Especially if it has the gearing your looking for.
  6. #26
    South Hills, PA
    4,052
    Bob my Pure Street friend has 6 G-force t-5's trans all in good working order, I'm sure he can let one or two go pretty cheap. let me know.....Bill
  7. #27
    [quote=Stroked03Cobra;293720 if you can make the parts work with your car its almost a no brainer.[/QUOTE]
    Looked int othis optio na bit more, and the parts are the issue ... I've got a LOT in a SFI bellhousing for the 2.3 now, and no option for that bolt pattern. It's mostly not an option.
    Quote Originally Posted by White2011 View Post
    Thanks for that, generally what I've been told ... and why the TKO's scare me.
    Thanks
    For sure some deals out there on them ... A faceplated trans really isnt a great option for me, I just drive too much to live with that.
    Thanks Bill, need to talk to you. Does he have so mant because they break a lot ;)
  8. #28
    turbo'd TBone7281's Avatar
    Pittsburgh, PA (Plum)
    609
    Original price: $1600
    GForce T-5 assembled by ProMotion Performance
    2.94 Ratio synchro 9310 high alloy gearset/ 94-95 T5 mustang kit
    Final gear is 59% OD (.59 ratio)
    Transmission was blueprinted and "custom assembled" whatever that means.
    Not a many miles on it, but we never had any problems with it. The stock T-5 lasted less than 3 weeks (street only) once the turbo went on. The GForce lived through several track excursions, so that is certainly a step in the right direction. I don't know what it would take to get it to work in your Capri, but it is for sale if you're interested. (The speedo is the main issue I can think of.)
    --> Tony <--
    2013 Audi S4
  9. #29
    For those following along at home ...
    Mostly have a decission, and suprisingly based on where I was, I'm going with G-Force. I have a good core to build on and am going to start ordering the parts for the build and have it put together.
    I'm so tired of looking at the options, but ultimately, just oo many out there working this way to not go this route.
    Thanks to everyone for input!
  10. #30
    Do you need a rebuild kit?
  11. #31
    I think i've asked like 5 times ... how much ;)
    Not sure what i'm going to do for sychro's now, thinking of different than the FMS parts ...
  12. #32
    Petersburg,PA. 16669
    816
    Bob...i've had a few G Force trannies and broke 3rd only once....steve wiped out 3rd three times and an input...my friend wiped out a brand new trans oon street tires...you will see if you buy just a kit and do it yourself....the 3-4 part of the main shaft slideson and 95% of the time are sloppy and rock back an forth oon the shaft and that to me is poor machining. also when 3rd breaks its a $500 fix. With Astro it is press fit and 3rd and 4th are seperate and is a $250 fix....plu all G Force uses first gear out of a tremec T5....it isnt even a stronger gear....if you had a g force kit and astro kit side by side you would see the superior quality astro offers. they arent even comparable...plus you can see the poor quality of metal g force has went to because after the tranny has a few miles on it you can see all the pits in the gears...like i said though hope it works. i have had a couple of thm and havent had too bad of luck....but we have been looking for a broekn astro tranny and have yet to even hear of one
    88 GT...and some boost
  1. Replies: 13
    Last Post: 01-13-2014, 10:10 AM
  2. Rim Choices.....
    Last Post: 07-06-2008, 08:58 PM
  3. wheel choices
    By 89stang in forum The Bar
    Last Post: 07-04-2008, 12:40 AM
  4. Heads//Cam Choices?
    Last Post: 04-30-2008, 11:10 PM
  5. Gear choices>>>>>>
    By LXguy88 in forum The Bar
    Last Post: 03-04-2008, 08:09 AM
