[ame="http://www.youtube.com/watch?v=RpYJRSus2ns"]2012 Boss 302 Stock Drag Radial Record - YouTube[/ame]
nice run , i wonder what a gear change will do for these cars
2022 BMW X4M Competition
2019 McLaren 720S
yep Its called nascar.
1969 Camaro restomod/project
1967 camaro
2011 mustang procharged
93 reef blue notch blk/int
92 calypso notch blk/int
86 t-type
1972 chevelle project
It takes a LOT of 12-second runs to equal 2 hours of open track time at a road course track day. They're both lots of fun though!
NiiiiCe!!! I had seen this on fb the other day right after he ran it! He races and has Stangs that run in the Super Stang and True Street classes at multiple NMRA events!
Bu-2000-bash
ALLSQUAD
Steel City Muscle Cars
CarCruises
Flashlight Drags
NMRA
UMTR
Modded Mustangs
NHSCC
Is the 5th gear in the MT-82 strong enough to handle full-power pulls on the drag strip? That definitely is a no-no with the T-5's.
6th is the od gear now running thru in fourth is like going thru in 3rd in a t5
First gear is useless enough in the MT82 equipped 5.0s with 3.73s, I couldn't imagine 4.56 or 4.88.
Plenty of bolt on 5.0s are needing to shift into 5th gear during a drag race.
MT82 (5.0)
Input Shaft - 26 Spline
1st - 3.66
2nd - 2.43
3rd - 1.69
4th - 1.32
5th - 1.00
6th - 0.65
I seem to cross the traps around 7300-7400 rpm in 4th off the spray.
theres been two different schools of thought with the new 5.0. Run a 28" tall tire and gear it for 3.73 or 3.90 and keep it in 4th crossing the traps for NA builds. OR run a 26" tire, gear it for 4.10-4.30 and power it through 5th.
2019 McLaren 720S
i'm for the later, you cant fear the gear
Jpcs car had 4.56s and spray
Ok - I see now that 4th in a T5 and 5th in a MT82 are both 1:1.
I've been told by many people that hammering 5th gear at the track in a T5 is asking for big trouble. I wonder how many passes those T-5s are surviving.
Gimme 26" tire and 4.30 gear and lets have some real fun.
There's one in the new MM&FF that put down 850RWHP with only a KB and a couple small fuel upgrades. Very impressive!
