Results 1 to 5 of 5
Thread: Fox vs SN95 Transmission Crossmember?
    Gibsonia, PA
    323
    Guys,
    Does anyone know if I can use a fox-style crossmember in my 95 GT?
    I know that the foxes had a sliding setup.
    Looking to make the conversion to the Tremec TKO a bit easier.
    Senior Member TJH64's Avatar
    Delmont PA
    320
    You will be able to re-use the stock crossmember, reinstall it 180* , slot the boltholes slightly, and add a 5/8" driveshaft spacer at the rearend. All should be good then
    Been there...done that. Good luck!
    Sep 2007
    Dayton PA
    3,795
    Definitely can't use a fox cross member. I tried before
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    South Hills, PA
    4,052
    x2!!!!
    You would thing the SN95 stuff would be bolt on! Guess not lol
  1. G Force Billet trans crossmember for a fox body
    Last Post: 11-12-2014, 10:01 AM
  2. Sn95 t5 for fox t5
    By blk93notch in forum Ford Vehicles
    Last Post: 08-03-2013, 07:28 PM
  3. looking for a fox crossmember
    By 92306gt in forum Wanted
    Last Post: 09-13-2008, 08:47 PM
  4. Replies: 13
    Last Post: 05-11-2008, 11:49 PM
  5. Transmission Crossmember
    By RUSH2112 in forum Ford Parts
    Last Post: 05-17-2007, 03:04 PM
