Results 1 to 4 of 4
Thread: 95 3.8 split port swapped fs
    hello everyone im thinking of selling my 95 split port swapped mustang as i found something thats a little more to my liking.
    the good
    almost dent free chassis with no rust.
    paints still in pretty good shape for being original no peeling or hard fading.
    its been split port swapped to a 2000 3.8 with a base 190 hp.
    new cold air intake.
    new clutch.
    newer tires.
    97-98 mustang gt wheels.
    3 good tires 1 about 50-60% tire.
    2 almost new tires to go with it to fit the 17's.
    all sensors are in good working order.
    all new fluids since i put the new motor in.
    new motor has right around 80k on it chassis has 136xxx and climbing as its a daily.
    has gt rear taillights paintmatched and spray tinted not real dark.
    has been claybared and cut and buffed recently to take off the oxidation.
    all power options are in excellent condition and working.
    10k hids installed all plug and play and operational.
    new white face gauges in the dash and nice trim bezels coutesy of roger stout.
    new calipers rotors and pads all around.
    brand new fuel tank,plus a brand new filler neck gasket installed.
    has had some brake lines replaced as they had rotted out the rest are in good condition.
    the underside has been wirewheeled and has had truck bedliner sprayed on to prevent any rust.( truck bed liner used not the other stuff that doesnt dry and holds in water)
    bads
    needs exhaust work. i have an off road h pipe for it just not the rear mufflers to finish the dual conversion.
    needs a front lower control arm on the right side.
    minor dings here and there and one dent on the left front fender.
    interior is about an 8 out of 10. needs cleaned.
    ac does not work right now i havent had it charged as its kinda cold outside.
    needs an sct tuner put on it to make the check engine light go away from the split port swap and unlock upwards of 50 plus hp and i think its around 20 more torque. thats on the engine alone plus maybe a few more when you put the duals on and the fact that i have a cold air intake on it.
    extras
    comes with the h pipe for it.
    the orig tribar wheels with 80-90% tires on them.
    orig tribar tail lights.
    gt foglights mint maybe used 1 month with most of the wiring for a stock install. (needs a switch)
    pioneer aftermarket headunit installed.
    if my asking price is met ill include my sub,box,and amp.
    sub is an alpine type r 10 with a dual 10 inch box thats ported and divided and an alpine v12 amp. plus a brand new set not installed massive audio 6x8 door speakers.all of that is over 500 bucks alone.
    asking price is 2500 and heres a pic or two.
    more pics added willing to drive to meet for sale with some consideration for gas if i have to come a long way.
    bumping it back to the front page. now taking reasonable offers. so hit me with some offers. wanna sell this and get some things done that need done.
  1. 95 v6 with a split port swap questions
    By punkbomb138 in forum Fox-SN95
    Last Post: 05-27-2011, 03:14 PM
  2. Evo Vs. PI swapped 98
    By Shorty429 in forum The Bar
    Last Post: 09-02-2009, 11:38 PM
  3. Replies: 19
    Last Post: 05-12-2008, 10:10 PM
  4. split port parts acquisition complete!
    Last Post: 05-06-2008, 08:46 AM
  5. split port vs not split port v6 question
    Last Post: 01-03-2008, 02:45 PM
