Results 1 to 11 of 11
Thread: irs bushings which ones?
    it looks like my 7.5 is hurt in my svo , i have a complete irs from an 03 cobra to put in , what should i do to it before i install it ? bushings ,braces .any other things that will help while its easier to get to things thanks for help
    Brookline
    2,897
    http://www.maximummotorsports.com/st...oducts_id=1344
    There's what you need to know. A lot of guys recommend a Billetflow diff brace as well, which I think is about $160.
    Monroeville
    856
    I'd definitely go with http://www.fulltiltboogieracing.com.
    Very popular on SVTP and ModFords.
    2004 SVT Cobra - sold
    2000 Yamaha R1
    2006 Yamaha R1 - Raven
    I learned the hard way that an IRS brace is a good idea...
    Full tilt boogie makes a nice kit and the maximum motorsport stuff is nice also. Call us we are dealers for both!
    Jeez Ray - that's some serious carnage!!
    yeahloh - in IRS in an SVO sounds awesome - love that car!
    Let me know how the install goes Troy. I have one bolted up in my 90 GT. Just need to finish up hooking up the brake lines. Plan on buying new wheels as the offset for anything but a 05+ will stick out past the fender lips.
    i already have 05 wheels on my svo Ed and i hope it goes well, i have other projects to work on this winter.
    Well 7.5 is out and on floor IRS should be mocked up sunday
    i ran in to a snag, i broke my last sawzall blade, trying to cut off the tail pipes , tomorrow i should have them out of the way and it up in place. i think i am going with the full tilt boggy parts
    map22 map22's Avatar
    Oct 2008
    monongahela
    458
    I've heard nothing but good things from full tilt boogie. I'll be buying my kit as soon as I feel like ripping my IRS out, and have access to my buddies lift.
    2003 Sonic Blue Cobra
    -Under the knife this winter
  1. Control arm bushings
    By fox fan in forum Ford Vehicles
    Last Post: 05-26-2013, 09:49 PM
  2. FEELER: Trade 04 IRS for 03/04 IRS
    By Venomous96 in forum Ford Vehicles
    Last Post: 08-23-2012, 10:51 PM
  3. rear bushings
    Last Post: 12-23-2008, 12:21 AM
  4. Needed Asap: Irs Front Diff Bushings
    By somethingclever in forum Ford Parts
    Last Post: 03-16-2008, 02:34 PM
  5. MM subframe bushings and KB alum Diff bushings
    By 724COBRA in forum Ford Vehicles
    Last Post: 02-14-2007, 03:17 PM
