Results 1 to 5 of 5
Thread: info needed here pls ford guys
    i b where im at
    674
    I found a 1985 5spd thunderbird will all the stuff work in my 91 fox ? Like the pedal and quadrant and cable ? And is this the same t5 tranny ?
    Anyinfo would help pls ! Thank you in advance
    Almost certainly, if its a t-bird with a 5 speed, it was a turbo coupe. The transmission will be the low torque rated 5 speed with 4.0X 1st gear, or 3.97 1st gear. The 85's was a transition year for the t-birds and everything is potentially early or late, so who knows.
    The t-bird quadrant is different. Not saying it cant be made to work, but as delivered it's different.
    Many better donors out there if that's all you are interested in.
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    If you pass on it, please let me know the location and other details. Thanks.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    i b where im at
    674
    Said the car awas swapped out to a 302 so tranny isn't a prob but he also said the quadrant was also from a gt ! So that's not a concern either
    just the pedals are a concern
    and is the crossmember different from auto to 5spd
    and is drive shaft diff
    With a swap car like thatx who knows. Thunderbird driveshaft is longer than mustang.
  1. HID info needed!
    By John4cam in forum General Tech
    Last Post: 03-07-2012, 06:57 AM
  2. need help here pls ford guys
    By stangfever in forum General Tech
    Last Post: 04-28-2010, 07:37 PM
  3. nitrous info needed
    By blaze00 in forum Fox-SN95
    Last Post: 05-11-2009, 12:48 AM
  4. supercharger info needed
    Last Post: 11-03-2008, 07:59 PM
  5. info on jeeps needed...
    Last Post: 10-30-2008, 08:11 PM
