Up for sale is a 1989 F-150 XLT Lariat "Racetruck"
-2 wheel drive
-Auto. 302 5.0.
-Has 172xxx miles.
-Trans shifts fine and motor was replaced about 15k miles ago, runs good.
-Newer tires in the back.
-Has the typical rust around the wheel wells in the back and behind the front wheels.
-Red cloth interior.
-Heat works VERY well.
-Napa Gold pads put on 7k miles ago.
-Oil just changed
-Has Posi. It DEFINITELY works.
-Has a bed liner
-Radio works fine
-P/w, P/l, Cruise works.
-Windshield wiper switch knob is broken off, use pliers.
-Gas gauge is broken, it goes to full when its over a quarter tank and starts bouncing around at 1/4 then goes back to working at about 1/8th. Only the front tank works. the rear tank does work but the seal around the middle is broken so it leaks out if you fill it up more than half way, it does function though.
-A/C doesn't work, but i never bothered looking into it considering this truck has wing windows. more A/C than you'll ever need.
-Tail gate is bent in the middle, The handle doesnt work so to put it down you have to pull on the rods on wither side to get it down.
Has the typical dents and dings of an older truck but the frame is solid and the bodys not that bad. Overall, not that bad of a truck. It just has some quirks, no real major issues with it.
Price is $1400 OBO
Could take more pictures if interested
Thanks,
Shawn
Email: Shwngrr@gmail.com
Cell: (412) 498-1327
